First post, by Joakim
- Oldbie
Hey
I was wondering if someone can post a picture on the ibm 760cd (or equivalent) board under the armrest. The board where the speaker connectors are attached.
I forgot to take a picture before I started working on it before I had worked on it. The connectors were damaged and I ended up soldering them directly to the board but I think I messed up the polarity of the speaker connectors because they sound very strange. (Might also be an other problem but I would like to make sure it's not the polarity.)
Is there a good way of knowing if you have connected the speakers correctly?
