First post, by Joakim
Hey
I was wondering if someone can post a picture on the ibm 760cd (or equivalent) board under the armrest. The board where the speaker connectors are attached.
I forgot to take a picture before I started working on it before I had worked on it. The connectors were damaged and I ended up soldering them directly to the board but I think I messed up the polarity of the speaker connectors because they sound very strange. (Might also be an other problem but I would like to make sure it's not the polarity.)
Is there a good way of knowing if you have connected the speakers correctly?
Reply 1 of 2, by Thermalwrong
Make sure the mylar film on the speakers is clean without any metallic debris on top. You can suck up the mylar if it's pushed in.
Here's a pic of my 760LD's RTC / keyboard / speakers PCB, hope it helps:
The attachment IBM-760LD-RTC-Speakers-PCB (Custom).JPG is no longer available
Reply 2 of 2, by Joakim
Thermalwrong wrote on 2024-01-22, 22:14:
Here's a pic of my 760LD's RTC / keyboard / speakers PCB, hope it helps:IBM-760LD-RTC-Speakers-PCB (Custom).JPG
Thank you very much.
It might be so simple that there is dirt or damage to the speakers. Would be interesting to look into replacements but then I suppose I will have to go down a rabbit hole of researching compatible speakers. 😀
