First post, by zb10948
Trying to supplement original power supply with a picoPSU. It would matter a lot if I could get away without -5V
I have ISAs in the system, video card, adlib card, XT-IDE.
Would there be any risk of powering up the board without -5VDC present?
Reply 1 of 14, by the3dfxdude
5150: The -5V is used for dram refresh and cassette circuitry depending on the revision. It was also passed through to the ISA connector. This made the -5V a spec item for years to come as the PC was originally designed with it.
https://minuszerodegrees.net/5150/misc/5150_power.htm
5160: The -5V is only passed through to the ISA connector.
https://minuszerodegrees.net/5160/misc/5160_power.htm
Any ISA supporting system: Some expansion cards require the use of the -5V. For the XT there were some stock expansion IBM options that may use it.
There is no risk at not having -5V in the XT, but it is possible things won't work fully. You need to pull out your cards and trace the -5V, then you'll know.
Reply 2 of 14, by zb10948
Ok, thanks I can proceed into testing.
I gather VGA cards are not known to use this rail?
Btw. I do not have an IBM XT, it's a XT clone from 1986 that's more closer to 5160 than 5150.
https://theretroweb.com/motherboards/s/olivetti-m19
Reply 3 of 14, by zb10948
If I'm not looking wrong and the -5VDC is the 5th rail from the top on the backside, looks like it's not wired on any of my cards. Great 😀
Reply 4 of 14, by the3dfxdude
I would not rule out all video cards entirely... but yes, I have not seen a vga card using -5V.
Reply 5 of 14, by Grzyb
It seems that there are VGA cards using -5V - Re: The Mystery -5V Rail
Reply 6 of 14, by zb10948
Seems my system doesn't use -5V at all.
I am about to make an adapter. But I don't know what exactly the blue "T" contact is. Any hints?
https://imgur.com/a/ly5hRqV
Reply 7 of 14, by Jo22
Sound cards like Sound Blasters (8-Bit) and PAS16 need -5v, too.
If you can't afford a proper PSU, you can still use something like a Voltage Blaster©®™.
Though I'm not a fan of this design myself, personally.
Reply 8 of 14, by zb10948
I did not see the mainboard label (on the imgur link) when I posted this question. As displayed, the system doesn't have/require -5V at all.
I'm good with picoPSU I just wanted to get extra info about what that "T" line could be. Everything else I can break out from the pico.
There seems to be no potential between T and G when system is powered. The others are what they say they are on the board label.
Reply 9 of 14, by Jo22
No idea what it's for, but it's not crucial maybe.
https://forum.vcfed.org/index.php?threads/oli … addition.69496/
Since PSU is in the monitor, normally, this could be monitor related.
On the other hand, I heard (read) there was an extra PSU for hard disk users available..
Because, the monitor wasn't strong enough in some cases.
Reply 10 of 14, by DaveDDS
Looking through a stack of old PSUs , I see that -5 is very low current. -12 is slightly more but still very low.
I'd guess that the '-' supplies are used for bias of some sort or other very low current applications
- I don't think I've ever seen logic/drives or other hardware actually powered from a '-' supply.
Given that PC PSUs are designed to support "worst case" (fully loaded system) - I'd guess that you
could just regulate -12 down(up?) to -5 .
You should of course check the actual current draw on -12 to be sure this doesn't overstress it.
Dave
Reply 12 of 14, by giantclam
DaveDDS wrote on 2024-01-24, 02:45:
A lot of PSUs from that era were designed that way anyhow ; the -12volt rail is produced by the SMPS output transformer, and the -5volt rail is derived from a linear regulator (7905) connected to that.
Reply 13 of 14, by zyga64
giantclam wrote on 2024-01-24, 03:05:
Exactly.
BTW. There is useful page with schematics of various ATX and AT PSUs: https://danyk.cz/s_atx_en.html
You can check that the 7905 linear regulator approach is used in the PC SMPS AT, cca 200W, among others.
1) VLSI SCAMP /286@20 /4M /CL-GD5422 /CMI8330
2) i420EX /486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
3) i430FX /K6-2@400 /64M /Rage Pro PCI /ES1370+YMF718
4) i440BX /P!!!750 /256M /MX440 /SBLive!
5) iB75 /3470s /4G /HD7750 /HDA
Reply 14 of 14, by giantclam
zyga64 wrote on 2024-01-24, 08:34:
...sigh .. thanks for posting that ~ remarks to a fair simpler time, wherein all we really cared about (or monitored), was whether the +5volt rail was behaving itself or not ... takes me back to the smell of rosin solder =)
