First post, by sdz
The card worked fine without the daughterboard installed, or with a know good daughterboard. At a first look, it didn't look that bad, there were a few scratches but no broken traces.
However, the right TMU, TMU0, showed signs of corrosion on about 25% of the pins.
The legs/pads would not take new solder, regardless of the amount of flux used, so I removed it to see what the actual damage is.
While the pads are still there, more than 90% of the affected ones don't have a connection to the traces anymore.
I proceeded to scrape off the soldermask and the corrosion until I could see bare copper. And it was worse than I expected.
