First post, by sdz
The card worked fine without the daughterboard installed, or with a know good daughterboard. At a first look, it didn't look that bad, there were a few scratches but no broken traces.
The attachment S1A.jpg is no longer available
However, the right TMU, TMU0, showed signs of corrosion on about 25% of the pins.
The attachment S1B.png is no longer available
The legs/pads would not take new solder, regardless of the amount of flux used, so I removed it to see what the actual damage is.
The attachment S1.png is no longer available
While the pads are still there, more than 90% of the affected ones don't have a connection to the traces anymore.
I proceeded to scrape off the soldermask and the corrosion until I could see bare copper. And it was worse than I expected.
The attachment S2.jpeg is no longer available
The attachment S3.jpeg is no longer available
Reply 1 of 4, by sdz
The attachment S4.jpeg is no longer available
The attachment S5.jpeg is no longer available
The attachment S6.jpeg is no longer available
Next I checked if the vias were still connected to the corresponding TMU1 and FBI pins, as well as GND and VCC. Most of them were salvageable.
The pads were really corroded even underneath, and when touched by the soldering iron, they would instantly lift. So, wire and liquid soldermask it is. Solder a couple, use soldermask, UV cure, and repeat.
The attachment S8.jpeg is no longer available
After all pads were fixed, and the soldermask cure, I scraped off the soldermask where the new TMU would be soldered:
The attachment S9.jpeg is no longer available
Reply 2 of 4, by sdz
Soldering the new TMU was a bit of a pain, but doable:
The attachment S10.jpg is no longer available
The attachment S11.jpg is no longer available
There was also a broken 10R resistor array, and after fixing that the card runs nicely in SLI.
Reply 3 of 4, by Ozzuneoj
Amazing work! That would have been quite an undertaking, but to get an X-24 working it was definitely worth the time. 😀
Reply 4 of 4, by sdz
Thanks! It wasn't actually that bad, quite a straightforward fix. And yes, fixing these cards is worth the time 😀
