Reply 620 of 3533, by sharangad
Running with mouseoff produced this:
DOSBox SVN, CPU speed:
SOUND.CFG
UYVETIKT
36 File(s)
12 Dir(s)
D:\NASCAR>nr1999r
DOS/4GW Professional Protected Mode Run-time Version 2.01a
Copyright (c) Tenberry Software, Inc. 1996
Copyright (c) 1994-1996 Papyrus Design Group, Inc. All rights reserved.
Version 2.00
Pentium-class machine.
Running from D: drive
UniVBE driver not present
Unable to read options.cfg file. Using defaults.
Unable to read race.cfg file. Using defaults.
Unable to read controls.cfg file. Using defaults.
Digital Sound
Port 220 IRQ 7 DMA 1
Conf irmed with SB16 8 ST
587008 Conventional
Triple Buffering
Warning: Did not find a match in mode table
NASCAR Racing 2 requires a mouse. Please load your mouse driver.
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 624 of 3533, by sharangad
Another test:
[EDIT] Skip this
https://1drv.ms/u/s!As-dKk-N73dSmCifLGR2NbOvzSCZ?e=AqsBjy
MD5: c463fbd3e46d442d32e59a32a6959544
Run this instead:
https://1drv.ms/u/s!As-dKk-N73dSmClVhXB3PuDy3ZF7?e=t8EAZ6
MD5: 899a97e9b0a685109d99e0a8ca942399
[/EDIT]
This should dump a few more calls. [EDIT] And test the FIFO transfer mechanism. This isn't documented very well[/EDIT].
There's something weird about VESA SetMode call 0x4F02. The mode passed isn't in the list passed by call 0x4f00 and queried by 0x4f01.
The mode numbers passed are: 0x807F and 0xC12E.
Reply 625 of 3533, by RaVeN-05
corrupted
executed in win98 got txt file which in attachment.
execution under dos , doesnot saves txt file, mode don't returns, everything on artifacts.
https://fex.net/s/zpe5zom
the video at fexnet is execution under dos, if you have vlc player you can press 'e' to look every frame, its still output something.
the command setmode.exe | more don't show anything at all
EDIT: the previous one you said to skip, works well.
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 626 of 3533, by sharangad
I think sending a V_FIFO_CONTEXT_INIT to the Verite was a mistake. This time I'm sending a V_FIFO_RESERVED1, which should be a noop equivalent.
I thought of sending a harmless V_FIFO_SQUARE to draw a square, but I don't know how to swap buffers yet (or even create a primary surface (i.e. I need it's address in verite space).
https://1drv.ms/u/s!As-dKk-N73dSmCqUOEFnZR0z3yHg?e=VOgpTb
MD5: f348d8691bb2d3a0ac9a42efb0d30c49
[EDIT] There should be another text file SM.txt, which I need.[/EDIT]
The results of modes 0x807F and 0xC12E. with VESA call 0x4F06 are weird (with BX=1 to query pixel resolutions).
For one of them I get a width of 640, linebytes 1280 and a max scanlines height of 0xCCC (3276)
and for the other width 1280, linebytes 1280 and max scanlines 0xCCC.
Reply 628 of 3533, by sharangad
Apologies for the delay, Turbo C++ is giving me problems. In particular the mode list query no longer works if the Int 10h call is from a subroutine:
[EDIT]
Skip this:
https://1drv.ms/u/s!As-dKk-N73dSmCvkVPh2OTJjMke5?e=wRfd5f
MD5: 84735e4c89fa5d3e302b886e7306904b
and skip this:
https://1drv.ms/u/s!As-dKk-N73dSmCwn0VtK-UZwW-6r?e=npm1q2
MD5: c9bcd7350cbbe7e16e713366a2a35470
Third time's the charm:
https://1drv.ms/u/s!As-dKk-N73dSmC0GcQ-LoIQoyE_8?e=sgdw4A
MD5: 5149e3bfc2c69bb1ce336cc3fcb85a9e
Everything should be working now.
[/EDIT]
Redirected output is what I would like OR you may end up with screen corruption or a lockup. You may just see a red rectangle in there (I seriously doubt this is going to work).
Reply 636 of 3533, by sharangad
Three more fifos:
https://1drv.ms/u/s!As-dKk-N73dSmC-8TeBnx4VzEw58?e=OHVVnX
MD5: eb3d2534c9dd8f42f7ccd61beded830e
Things to check:
1) Stability/No lockups
2) Corruption
3) Red Square appearing on screen.
4) 60 Hz on exit.
Reply 639 of 3533, by sharangad
I lied here're two more:
https://1drv.ms/u/s!As-dKk-N73dSmDHFuQy-1YD84M_J?e=IsZapl
MD5: 492639ab321ac65913882fdb1495b94a
With FIFO5 and 6 there should be a delay. If this works, FIFO6 *might* render a red square.
