Reply 380 of 451, by Black6spdZ
I don't see P2B-VT listed.. hardware incompatibility?
Reply 381 of 451, by DenizOezmen
Black6spdZ wrote on 2024-03-02, 20:35:
Only mods having been tested at least once on real hardware (and those closely related to tested ones) have been published.
Regarding the P2B-VT, the last time we encountered one it was driven by a Phoenix BIOS (not Award), so the mod wasn't applicable. The name is used for OEM boards and describes at least two different boards, using either a 440BX or a VIA Apollo 133.
Do you have one with an Award BIOS?
Reply 382 of 451, by Eivind
Is there any way of disabling the PnP extension on the BIOS? (I have the P3B-F)
I'm in the process of building my own sound card based on the Crystal CS4237B, and while the modded BIOS works like a champ I'd love to be able to play around with having the CS chip be untouched by the PnP initialization routines at boot time.
I tried using the CBROM utility to remove the "AWARDEXT.ROM" part of the BIOS, thinking that it might be it - but it looks like the PnP stuff is part of the main BIOS code?
TinyLlama 3
ITX-Llama motherboard
TinyLlama SBC
Reply 383 of 451, by Zerthimon
I think it's the bios setup option PNP OS yes/no. If you set it to yes, then bios doesn't configure PNP devices.
Reply 384 of 451, by maxtherabbit
Zerthimon wrote on 2024-03-19, 16:01:
Correct
Reply 385 of 451, by Eivind
maxtherabbit wrote on 2024-03-19, 21:46:
Correct
Well, it detects and lists the cards regardless of the PnP OS setting, making me think it still runs the enumeration, isolation and initialization processes - which is what I'd like to avoid.
Of course the easiest course of action would be to test my sound card on an older motherboard made before PnP (~1994/95), but I don't have one at hand at the moment, that's why I was asking whether it was possible to disable the PnP extension on the modded BIOS.
TinyLlama 3
TinyLlama SBC
Reply 386 of 451, by mrdjey
I am trying to modify a Chaintech CT6VIA3 bios to recognize a VIA C3 1200A cpu and it seems that after reading this topic this has been done for a CUBX-E with 1008cu004_20230709.
is it just a case of extracting the microcode from it and adding that to my bios using CBROM or is there more to it?
AMD K6-2+ 570ACZ | Aopen AX59 Pro | 3DFX Voodoo 3 2000 | AWE32
Reply 387 of 451, by dparks256
Hey all! P2B-B v1.01 and P3B-F 1.03 owner here, I was stoked to find this thread as I've been trying for a couple months to get a Coppermine or Tualatin operational in a AT board for a cool IBM 5155 build I've been working on. I see that P2B-B support is new. Has anyone had any luck with this board? I wasnt having much luck with the stock beta BIOS with coppermine or newer cpus. Anyone need any experiments performed? I have successfully flashed my board with this BIOS, and have a DIP programmer for recovery if something goes wrong. I have several varieties of slockets, some katmai, coppermine, and tualatin cpus, some tualatons are coppermine modded, some not, and would be happy to help with testing. My board has been modded to add jumperfree support by adding a pin header to the JEN pads, though I've been having a fair amount of difficulty getting jumper free to behave. Anyways, long story short, if anyone has any tips to get a coppermine or coppermine modded Tualatin working in the P2B-B, awesome, I'd love to hear them, and if not, I'd love to be of help testing anything needed to assist with P2B-B bios development.
Reply 388 of 451, by SWZSSR
Was wondering if you would add 128gb+ support & anything else useful to the ASUS PVI-486SP3 ?
The latest bios is AWARD core version 4.51 (https://theretroweb.com/motherboard/bios/si4i … ff906840735.zip)
Sounds absolutely crazy i know, but it will allow any 7200rpm drive to work\any SATA drive on a adapter with the ability to load up multiple FAT16 or FAT32 Partitions with an entire 30gb+ library of DOS games\soundbanks etc!
M919(3.4bf)/5x86@180/Banshee/SoundscapeElite/DOS6.22
5TH/Dual233MMX/MGA2164W/Voodoo2/AWE64Gold/NT4.0&Win9X
P5A(1.6)/K6-3+550/Ti500/EWS64XL/WIN9X
CUV266-D/Dual1.4TUAL/HD4670AGP/XONAR/XP
780i/QX9650/3x8800U/XiFi/VISTAx64
X79Saber/4960X/TITANX/Bravura/XP
Reply 389 of 451, by DenizOezmen
Eivind wrote on 2024-03-19, 12:12:
Pretty much, yes. AWARDEXT.ROM contains integral parts of the setup code (i.e. the menu logic and strings for BIOS setup), so removing it will break the BIOS menu.
I'm currently not sure which part of the logic exactly remains after setting the PnP setup option to "Disabled" ...
mrdjey wrote on 2024-03-29, 13:18:
Via C3 processors don't know the concept of microcode updates, so extracting/adding microcode update files will only affect Intel processors. For the mods here, BIOS logic had to be changed. The most important changes make sure the BIOS can correctly enable/disable the L2 cache and skip any microcode update attempt. The rest is mostly cosmetical.
So the question would be: Is there anything that doesn't work as expected with a C3 on your board (aside from wrong info printed on POST)?
dparks256 wrote on 2024-04-04, 04:15:
Someone wrote me an email and used the BIOS mod with a Coppermine 1000 (133 x 7.5), so in general it should work, assuming a compatible PWM controller chip is on board. Not sure if that's a given on all P2B-Bs. According to the ASUS web site, Coppermine support officially starts from board revision 1.02.
Does any Coppermine work with your board at all?
We experimented a bit with JEN, but jumperfree support in this BIOS version is pretty incomplete. We couldn't get the menu settings to stay applied.
SWZSSR wrote on 2024-04-04, 06:21:
That would be a whole new platform to disassemble. Not sure which of the mods from the thread here would apply(?).
Drives above 128 GB would mean adding LBA48 support, which I will not try to implement on my own. There's a better chance to get this working by using an extension ROM like XTIDE.
Reply 390 of 451, by Mr.Hunt
Hello! Is anyone have already patched BIOS for P3V4X ? Please give me. Thank you!
Reply 391 of 451, by DenizOezmen
Mr.Hunt wrote on 2024-05-01, 18:43:
The link to the download site is in the first post, about one third of the way down from the top.
Reply 392 of 451, by SWZSSR
Issue will be your VRM controller chip. It cannot supply anything under 1.8volt. You most likely have the HIP6019CB or HIP6004ACB chip which is the culprit.
Necroware did a video on this but with an earlier board
https://youtu.be/-EXpNvG7aMQ?si=dyuxMI4IJ5u-LZ3R
Reply 393 of 451, by shevalier
Hi, its me again)
Its possible to add AGP sideband disable|enable option for 440BX boards?
Not all video cards reach driver loading at 89 MHz AGP
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Diamond monster sound MX300
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value
Reply 394 of 451, by Gmlb256
An option to toggle SBA thru the BIOS settings would be nice, if possible. There are video cards that have this feature implemented in their VBIOS which gets to be enabled by default.
Reply 395 of 451, by karakarga
Deniz,
I have a 990FX chipset based Gigabyte 990FXA-UD7 version 1.0 mainboard. It has build on legacy Award bios, file size is 4 Megabytes. (990FXA-UD7 version 3.0 build on UEFI type AMI bios, totally different!)
I couldn't managed to integrate NvmExpressDxe_4.ffs inside the latest "99FXAUD7.11d" beta bios because it is a legacy bios, tried with UEFITool.exe (Version 0.28.0)
Made cpu microcode update modifications and ethernet etc. update with UBU, but I can not flash it inside the bios.
I have tried many parameters:
awardflash 9FXAUD73.FDe /cc /cd /cp /sn /wb /py /sn /qi /nbl /r /cks etc. None of them worked! 🙁 [Awardflash version: 8.99]
The error messages:
Binary file is not Award Bios!
Unknown Flash Type!
The program file's BIOS-Lock String does not match with your system!
The program file's part number does not match with your system!
Do you know flashing parameters for modified bios file inside Award bios? Can you please help?
Notes:
- Award BIOS Editor 1.0 did not successfully open source file, many errors.
- Uniflash is too old, can not see the newer system.
- One of the sources explains that, bios string modification is necessary by using CBROM199 and a hex editor, but seemed too complex to me and I am not sure about the result.
https://winraid.level1techs.com/t/guide-award … 5119/121?page=6
Edit Note: I have mixed bios versions for rev 1 and 3, now corrected!
Reply 396 of 451, by DenizOezmen
shevalier wrote on 2024-05-14, 15:25:
Hi, its me again)
I've looked around several times now, but haven't yet been able to find the location where AGPCMD is programmed. (It has to be somewhere, since "AGP Enable" has to be set.) I'll come back to this if I find it.
Reply 397 of 451, by smtkr
DenizOezmen wrote on 2024-05-23, 07:25:
Hi, its me again)
Have you checked in the video BIOS?
Reply 398 of 451, by shevalier
Tnx
By the way, I don’t know why, but Asus does not set the memory controller bits for 100+ MHz capability at CAh register.
CUBX-l matherboard with last bios
Reply 399 of 451, by DenizOezmen
smtkr wrote on 2024-05-23, 22:55:
Do you mean the video BIOS of a graphics card? No, I wouldn't suspect chipset-specific programming there(?). The mainboard BIOS does not have a video BIOS of its own. Up to now, I've looked in the main image and the boot block.
shevalier wrote on 2024-05-26, 06:37:
Not sure about that, but it seems to be related things like DIMM layout (less than or equal to four sockets) and actual number of rows present. At least Coreboot reproduces it this way. Maybe 100 MHz buffer operation becomes unstable otherwise? (According to the datasheet, buffer frequency and bus frequency can be mixed at will.)
