Hey everyone,
I recently picked up a Roland RA-50, and I’m running into an issue I’d love some help with. Every time I power it on (using a 9V DC adapter), I get a "Check Internal Battery" message on the display. The unit seems to work fine otherwise, but I’m worried it might be losing settings or something when powered off.
From what I’ve dug up online, it sounds like the internal battery is probably a CR2032 3V lithium coin cell for memory backup (like in a lot of Roland gear from that era). I saw some mentions of this on Gearspace and Syntaur’s parts list, but I haven’t cracked it open yet to confirm.
Couple of questions for anyone who’s dealt with this:
1. Is the "Check Internal Battery" message definitely a sign it’s dead or dying? Or could it be something else tripping the error?
2. If it is the battery, how tricky is it to replace on the RA-50? I’m decent with a soldering iron but don’t want to mess up the board.
3. Any chance this affects more than just memory—like, could it stop the unit from booting properly if it gets worse?
4. Where’s the battery even located? Any tips on accessing it without a service manual? (I couldn’t find one online yet.)
I saw some folks here mentioned 3V readings on chips and battery stuff earlier in the thread, so I figured this might be the right place to ask. Any advice or experiences with the RA-50 (or similar Roland units) would be awesome. Thanks in advance!
Cheers,
MarsEverythingTech
