Reply 1020 of 3298, by sharangad
In other news, I've sourced the IndyCar.exe patched version from here:
https://racesimcentral.net/download/rendition … ycar-exe-581kb/
Having problems running it.
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 1021 of 3298, by sharangad
I also seem to be having issues sending an [ALT]+[ M ] command to the game. Dosbox registers the keystroke coming in correctly from the DosClient, but it seems to not register with the game.
In fact I can't send any [ALT] strokes through.
Reply 1022 of 3298, by sharangad
A test I need running from someone with a Verité board, @Raven-05, anyone:
https://1drv.ms/u/s!As-dKk-N73dSmGp3YCXudfApzYr6?e=K1PA4x
MD5: 8871b425fa752e6a60fd1c820ada98fc
Reply 1024 of 3298, by sharangad
robertmo3 wrote on 2024-04-15, 01:18:
sharangad wrote on 2024-04-15, 00:41:
robertmo3 wrote on 2024-04-15, 00:24:
can you show where exactly?
Here:
no, it is not:
Different frame. That building changes colour from frame to frame and that's been happening in all videos.
Reply 1025 of 3298, by robertmo3
i have watched whole movie frame by frame
absolutely no building has any problems
not a single frame is wrong here
https://www.youtube.com/watch?v=zY91QMo8dnc
btw- your frame is from a different movie
the movie i am talking about has no cockpit
your frame has cockpit
Reply 1026 of 3298, by sharangad
robertmo3 wrote on 2024-04-15, 07:47:
i have watched whole movie frame by frame absolutely no building has any problems not a single frame is wrong here https://www.y […]
Would you say this is a regression?
Reply 1027 of 3298, by robertmo3
yes i aleady said that before
just watch the movie i linked to
just try your old executable used to make that movie
Reply 1030 of 3298, by robertmo3
on main page you choose "files" from the menu
than you choose game name
than the file name
or you can just use this direct link
https://racesimcentral.net/indycar-racing-ii/?sim=downloads
the file is called
Rendition INDYCAR.EXE - 581KB
ICR2REND.zip – 581.85 KB
you can click it or choose direct link
https://racesimcentral.net/download/rendition … mstv=1713178065
Reply 1031 of 3298, by robertmo3
on youtube you can click in the bottom right corner of a movie on a gear icon (options) it allows setting resolution and playback speed.
0.25 may be fine for watching every frame, you can use arrow keys left and right to skip back or forward
if that is not enough you can download movie with "4k video downloader"
https://www.4kdownload.com/products/videodownloader-42
you can play them in VLC media player
https://www.videolan.org/vlc/index.html
VLC media player allows watching movies frame by frame by pressing key "e"
you can also keep "e" pressed
if a recording was done in 60fps, this way by counting frames you can tell game's real fps
Reply 1032 of 3298, by sharangad
RaVeN-05 wrote on 2024-04-15, 10:45:
Icr2 link not valid. Redirects to main web page.
I assume it's patched for v2000 and that's why it's not runs?
@vetz can you help please?
Indycar.exe does work. I was messing around with RReady and messed something up.
Reply 1033 of 3298, by RaVeN-05
to make indycar2 patched to work you need to use
Rendition v1-v2 SPD3D.UC Switcher - 36.3KB
spdrsc.zip – 36.34 KB
and use v1 spd3d
with v2 spd3d on v2000 i can't run it from pure dos, only in restart to dos mode after windows get loaded
v1 on v1000 directly start from pure dos
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 1034 of 3298, by sharangad
RaVeN-05 wrote on 2024-04-15, 14:54:
to make indycar2 patched to work you need to use […]
and use v1 spd3d
Got it working. Thanks.
Dust particles don't render with rready. Is there something I have to do to enable it?
Reply 1035 of 3298, by RaVeN-05
sharangad wrote on 2024-04-15, 00:52:
idk , i don't know its seems worked for me out of the box that dust. maybe check graphic menu and set everything to on?
need to chech, will tell later....
Reply 1036 of 3298, by sharangad
RaVeN-05 wrote on 2024-04-15, 15:06:
Thanks @Raven-05.
Reply 1037 of 3298, by sharangad
I seem to have randomly high latency with named pipes. Sometimes it'll run really well. Somtimes it'll chug. Asynchronous named pipe IO appears with large buffers appears to be the culprit. But I have no idea why it does that.[EDIT] MIght have to switch to socket IO. But I do remember it worked reliably earlier on, so it might just be soemthing I've messed up.[/EDIT]
The Rendition enhanced levels have textures whose sizes I can't sometimes determine. Sometimes they swing from right as rain to a weird mess. Some textures can't be sized at all, I haven't been able to get them to render. The standard levels are all fine now, but those algorithms don't work for the enhanced levels. The standard levels use 4 bit paletted textures and the enhanced stuff uses 16 bit texels.
Reply 1039 of 3298, by sharangad
RaVeN-05 wrote on 2024-04-15, 15:48:
Yes I checked, in Icr2
Options->Graphics->smoke/dirt - > on
@Raven-05 or anyone with a Rendition board:
Could you run this from Windows?
I need the two linebytes values it returns (RRedline, they should be the same under Speedy3D).
https://1drv.ms/u/s!As-dKk-N73dSmGs8rmgW8RwYAhir?e=K8UCeL
MD5: 6345060e94ea543c0d703705967df486
