Original Lunar Lander
First post, by GeekOfDeath
I've downloaded a PDP-11 Emulator in order to play the original Lunar Lander. Unfortunately, the Lunar Lander program can only run on the DOS version of the emulator. This, I figured was a piece of cake with DOSBox.
The unfortunate part is that DOSBox refuses to admit it has enough memory to play the game; it spits out....
?Insufficient memory
I checked around, and typed in....
memsize 96
.... and it still didn't work. I took the risk of setting the memory to more than what I actually have.
I'd like to know if there's a way to fix this. I run Windows Vista Home Basic (yes, Vista), I have an Intel Core 2 Duo @ ~2 GHz and have 2 GB of RAM.
Reply 1 of 12, by MiniMax
Rank Moderator
Moderator
You need to turn EMS off before running E11.
Either using the command
Z:\>ems off
before running E11, or editing dosbox.conf with ems=false.
_________________
Reply 2 of 12, by GeekOfDeath
For some reason, the computer refuses to allow me to save the config file, and shutting off EMS while in DOSBox has not worked.
"Access to C:\Program Files\DOSBox-0.72\dosbox.conf was denied."
It's Vista. I know it is.
EDIT: Ok, I managed to save the config file. Now, it still doesn't work.
Reply 3 of 12, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
In Vista you don'T have permission to write to files in the /program files/ directories. Either assign yourself the correct rights for dosbox.conf or make a new one at a location you have the necessary rights and start Dosbox with this conf file (see the readme).
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 12, by GeekOfDeath
In case you missed the edit (out posts were close), I managed to get the config file saved.
Unfortunately, I still can't run E11.
Reply 5 of 12, by MiniMax
Rank Moderator
Moderator
And EMS is off?
_________________
Reply 6 of 12, by GeekOfDeath
Yes it was off, but I'll try again anyways.
EDIT: No, it still doesn't work.
Reply 7 of 12, by MiniMax
Rank Moderator
Moderator
And how do you know it is off?
_________________
Reply 8 of 12, by GeekOfDeath
Typing "EMS" into the console will result the response, "false".
Reply 9 of 12, by MiniMax
Rank Moderator
Moderator
Ok 😀
Strange, it worked for me. Created a C-drive for DOSBox, ran the INSTALL.EXE which installed in C:\E11. Tried to run the E11.EXE without modifications to DOSBox and was greeted with the memory error message. Turned EMS off, re-ran E11.EXE and it started up.
_________________
Reply 10 of 12, by wd
Rank DOSBox Author
DOSBox Author
turn off ems AND xms
Reply 11 of 12, by MiniMax
Rank Moderator
Moderator
Ahh - I guess I turned off XMS first, saw that didn't work, then turned off EMS and it worked. So both needs to be off.
_________________
Reply 12 of 12, by GeekOfDeath
Yes! It works! Thanks a million!
