First post, by GeekOfDeath
I've downloaded a PDP-11 Emulator in order to play the original Lunar Lander. Unfortunately, the Lunar Lander program can only run on the DOS version of the emulator. This, I figured was a piece of cake with DOSBox.
The unfortunate part is that DOSBox refuses to admit it has enough memory to play the game; it spits out....
?Insufficient memory
I checked around, and typed in....
memsize 96
.... and it still didn't work. I took the risk of setting the memory to more than what I actually have.
I'd like to know if there's a way to fix this. I run Windows Vista Home Basic (yes, Vista), I have an Intel Core 2 Duo @ ~2 GHz and have 2 GB of RAM.
