Reply 52741 of 59470, by rav85
mtest001 wrote on 2024-04-24, 19:39:
rav85 wrote on 2024-04-24, 19:24:
I got one like this, it starts and works Pentium 200 MMX 128MB Edo MATROX 590 05 […]
Pentium 200 MMX
128MB Edo
MATROX 590 05
What motherboard is this ? Do you have a mix of EDO and SD-RAM? EIDT: Ha no I presume this is the L2 cache module ?
Reply 52742 of 59470, by rav85
Any idea what it is?
Reply 52743 of 59470, by rav85
Broken chips 🙁
Reply 52745 of 59470, by BitWrangler
One chip two chip, dead chip blew chip. If not motors, some other high power inductive load.
Reply 52746 of 59470, by H3nrik V!
Wow, that's one for letting out the magic smoke 😲
Reply 52747 of 59470, by BitWrangler
Left a big enough hole to get it back in though, go to grocery store and get a bottle of liquid smoke flavoring and a turkey baster...... 🤣
Reply 52748 of 59470, by Jccwu
I loved the boxed versions hardware
Sound card's music
Reply 52751 of 59470, by predator_085
Good some parts for rebuilding my Voodoo 3 System
Gigabyte GA-7IXE mainboard
Athlon 700 mhz ( K7700MTR51B) Cpu
Reply 52752 of 59470, by InTheStudy
Tiido wrote on 2024-04-25, 07:58:
It is a some sort of motor controller, that has suffered a catastrophic failure...
I was wondering what you could be driving that would cause you to detonate a DAC. That would also explain the fuse and external power input on the inner edge.
Reply 52753 of 59470, by Mandrew
Jccwu wrote on 2024-04-25, 15:42:
and more photos
Love the Voodoo cards casually piled up like it's nothing. 😁
Great haul.
Reply 52754 of 59470, by MMaximus
PC@LIVE wrote on 2024-04-24, 22:49:
For the PC XT I found an interesting solution, for the video card, I have an 8-bit ISA, which should be a Hercules (or a monochrome one), the connector for the monitor is with 9 pins, unlike VGA monitors that have 15 pins, so to solve I had to find an 8-bit ISA VGA, or a monitor with 9 pin input, or a 9 to 15 pin adapter.
After various searches, I found a fairly inexpensive solution, a connection cable to the monitor, with VGA port on one side and 9-pin port on the other.
Just replace it with that of the monitor, which has two VGA input outputs, and connect the 9-pin to the Hercules ISA 8-bit, while the other goes to the VGA monitor.
There are some early VGA cards that have a 9pin connector, but if that's not what you have in your XT, that's not gonna work. I assume you have some sort of CGA or Hercules card and this will definitely require signal conversion if you want to use a VGA monitor.
Hard Disk Sounds
Reply 52755 of 59470, by PC@LIVE
MMaximus wrote on 2024-04-25, 16:27:
Yes, exactly, I want to use an 8-bit ISA card, probably Hercules (or CGA), which has a 9-pin video output. Using the cable I ordered, it will connect the video card (9 pin) to the VGA monitor (15 pin). The only doubt is whether the Hercules frequencies are supported by the VGA monitor, because otherwise I would have to find a monitor that has no problems with those frequencies.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
Reply 52756 of 59470, by weedeewee
PC@LIVE wrote on 2024-04-25, 17:30:
It's not just the frequencies.
MDA,CGA & EGA all output TTL signal levels 5V (If I recall correctly)
While VGA is analog output max signal level is 0.7V maybe 1V.
Do not ask Why !
Reply 52757 of 59470, by PC@LIVE
weedeewee wrote on 2024-04-25, 17:33:
It's not just the frequencies. MDA,CGA & EGA all output TTL signal levels 5V (If I recall correctly) While VGA is analog output […]
Ouch, if so and probably yes, I spent money on a cable that will be of no use, honestly I didn't know this Volt thing, at this point the only solution is a 9-15 pin converter, I've seen one used in Necroware, I don't know what it costs but the alternative to that is a VGA ISA 8 bit like trident or gremlin.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 52758 of 59470, by lolo799
Just got the one on the right, it's a bit special!
The attachment joysticks.jpg is no longer available
The attachment joysticks1.jpg is no longer available
Spoiler
The attachment joysticks2.jpg is no longer available
Spoiler
The attachment joystick-sticker.jpg is no longer available
Reply 52759 of 59470, by H3nrik V!
Jccwu wrote on 2024-04-25, 15:34:
part.2
Is that trackball actually wireless? I see it has some radio like logo next to the ball, but also what looks like a cord? And wouldn't "WIRELESS" be written all over the box?
