Reply 1201 of 3199, by robertmo3
nascar racing 2 works even on 2 cores
cart racing 2 needs 3 cores now (used to be 2 cores only before)
keyboard is ok now
Reply 1202 of 3199, by robertmo3
robertmo3 wrote on 2024-04-29, 06:49:
also tomb raider makes some error popups but works, but if you don't close the popups it works slowly - this is a new feature of latest build
actually you don't have to close them - game works fine
Reply 1203 of 3199, by sharangad
robertmo3 wrote on 2024-04-30, 14:03:
keyboard is ok now
Are the frame rates better with cart racing?
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 1204 of 3199, by sharangad
keyboard is ok now
Keyboard problems were a bug.
Reply 1205 of 3199, by robertmo3
during the game when i stand in a row of cars not pressing anything it has increased from 17 fps (2024.04.28) to 21 fps (2024.04.30)
Reply 1206 of 3199, by sharangad
robertmo3 wrote on 2024-04-30, 20:32:
I need to tweak this more. My target is 30 fps for ICR2 with a discrete GPU and a quad core.
Reply 1207 of 3199, by robertmo3
sometimes any game starts with slower fps, but pressing alt-tab fixes that
Reply 1208 of 3199, by sharangad
robertmo3 wrote on 2024-05-01, 08:36:
That's a focus issue. Not entirely sure why that happens. The full screen window should automatically steal focus.
Reply 1209 of 3199, by sharangad
Mem writes are a big problem, they're written one at a time, but need to be processed in chunks for efficiency, but doing it right is a bit of a problem. There's a lot of overhead involved in sending byte mem writes. The address which is 4 bytes has to be sent across, 4 bytes + the actual byte so 5 bytes have to transferred for every byte. Secondly when mem writes stop pending writes have to be written out. A reliable method of detecting when writes have stopped is needed.
This has to work using minimal cpu and very quickly.
The black screen delays are because of mem writes.
Reply 1210 of 3199, by robertmo3
so if you developed it normally without those freaky pipes all these problems would magically be gone?
Reply 1211 of 3199, by sharangad
A lot of them. The instability and cpu load would go down . The mem write problem would still be there though. Opengl isn't designed for textures/framebuffers to be updated one byte at a time.
Reply 1212 of 3199, by robertmo3
sharangad wrote on 2024-05-03, 05:52:
what about direct3d?
Reply 1213 of 3199, by robertmo3
you know what, just make it normally. In any case you can always bring pipes back.
Reply 1214 of 3199, by sharangad
robertmo3 wrote on 2024-05-03, 06:14:
It's the same.
The problem is that the this isn't real video memory.
For instance if a single byte's written to the screen, the mem write has to be turned into a texture (or a pixel draw) and drawn to the screen. On an actual Verité the write automatically updates the screen. because you're modifying what's on screen This needs one or more OpenGL commands each of which takes up CPU. It's better to group a bunch of adjacent pixels and draw them together to lower CPU overhead. These commands aren't lightweight in OpenGL and Direct3D. The problem is the frame buffer isn't directly accessible in any modern rendering API, even Vulkan. If you want to draw something to the screen, you can't POKE (1-4 bytes) into VRAM. You have to select the screen as your output destination and draw a pixel (very slow and inefficient) or render a 1x1 texture onto the screen. Neither of these are optimal for 1,2 or 4 byte writes.
RRedline doesn't have this problem. The API recommends calling V_LockBuffer to gain access to video RAM. This waits for queued commands to be completed and returns a memory block to write to. Once writing's done, V_UnlockBuffer's called to turn the Verité on. RReady uses updates the screen at this time before resuming rendering. With RRedline direct memory writes are also possible (if you query the VRAM address), but nobody does that.
Pretty much all the Speedy3D apps I've seen so far use direct mem writes/POKEs to render splash screen's and menus use V_FIFO_MEM_WRITE_SPRITE (another ridiculously slow call). VL_MemWriteSprite is available with RRedline as well, but nothing uses it.
Reply 1215 of 3199, by sharangad
robertmo3 wrote on 2024-05-03, 06:26:
I can't legally distribute it if I do that.
Reply 1216 of 3199, by sharangad
I think I've fixed your Tomb Raider "This program has performed an illegal operation" dialog. This is what was keeping it from running on my 2 of my Intel based systems (Sandy Bridge and 8th gen). It already ran in slow mo on my Haswell based HD4000 machine.
Don't know why Sandy/8th gen doesn't render anything with integrated graphics. Need to look at that now.
Reply 1217 of 3199, by robertmo3
my integrated graphics works but jerky
Reply 1218 of 3199, by sharangad
robertmo3 wrote on 2024-05-03, 07:02:
It works on HD4000 but not HD2000 nor the UHD620 (laptop) for me.
I also always get an error on HD2000 much like what I get randomly with my GTX1060/Ryzen 7. I need to sort this error out, the random instability is related to it.
Reply 1219 of 3199, by robertmo3
my is HD2500
