Reply 1222 of 2948, by sharangad
sharangad wrote on 2024-05-03, 08:10:
sharangad wrote on 2024-05-03, 08:08:
robertmo3 wrote on 2024-05-03, 08:03:
my is HD2500
Do you have an SSD?
My old i7 has an HDD and the uhd 620 has a slow SSD (slow write speeds).
My Dev machine and the hd4000 have fast sata SSD s
https://www.youtube.com/@sharangadayananda
Reply 1223 of 2948, by sharangad
That might be the cause of it. Unknown command buffer elements are logged. That might be why it crashes.
Reply 1224 of 2948, by sharangad
It shouldn't affect it. Will test that in a bit.
Reply 1226 of 2948, by sharangad
robertmo3 wrote on 2024-05-03, 08:26:
UHD620 is ogl 4 as well and it doesn't work there either. SIngle frame.
Reply 1227 of 2948, by robertmo3
try spd3d.uc from tomb raider rendbeta4
Reply 1228 of 2948, by sharangad
robertmo3 wrote on 2024-05-03, 08:51:
Will do.
It wasn't the logging. Named pipe comms do produce gibberish on the Sandy Bridge based machine and I don't know why. It happens randomly on my dev machine as well.
Reply 1230 of 2948, by robertmo3
but the game does
Reply 1232 of 2948, by sharangad
sharangad wrote on 2024-05-03, 09:14:
robertmo3 wrote on 2024-05-03, 08:59:
but the game does
Ooh! Particle effects and smoke.
My bad, the particles were already there. Is there something specific I need to see with beta4?
Reply 1233 of 2948, by robertmo3
no that was actually a mistake on my side 😉
Reply 1234 of 2948, by robertmo3
i mean i have cart racing working on 2 cores slowed down to 1,5GHz with integrated graphics (no idea why it didn't work before)
(i thought that was cause of different .uc but it wasn't)
Reply 1235 of 2948, by robertmo3
i think it didn't cause i was using the tr .uc 😉
Reply 1236 of 2948, by robertmo3
it looks the problem to test cart racing is you have to press alt-tab to refocus and we know alt is buggy
Reply 1237 of 2948, by robertmo3
cart racing only works fast for me (with 2 cores and integrated graphics) when i have focus set to dosbox-rendition while fullscreen plays in the background.
when i refocus to fullscreen it is slow again
Reply 1238 of 2948, by robertmo3
i made cart racing work on 2 cores by setting priority to dosbox to higher
Reply 1239 of 2948, by robertmo3
[sdl]
priority = higher,higher
