Reply 1340 of 3533, by robertmo3
as for rebel moon rising
briefings are displayed properly so far with correct pictures of targets and scrollable text
i think saving failed to record the targets i have destroyed 8 turrets in first training level but it didn't accepted that.
i started new game without saving and managed to finish 1st level
but there is no key for starting jetpack in rebel moon so i guess at some point some level might be not finishable 😉
or at least that feature will be inaccessible 😉 but maybe it is started automatically and only cannot be turned off/on again
maybe you don't have to turn it off
you fly with jump
turrets are not displayed properly but are visible, but i guess that has to be checked on real card first
and rready has to support rebel moon properly first.
turrets are being properly displayed in -vga mode so i guess it may be a problem of rready
Reply 1342 of 3533, by robertmo3
noticed there is something wrong with mouse controls in rebel moon in rready - it only rotates left/right by 180 degrees. you can rotate right more is you keep moving mouse back/forward at the same time, moving left is not possible this way.
Reply 1343 of 3533, by robertmo3
the 3dblaster version works on verite engine version too
so far with a drill only, shooting pistol crushes it
Reply 1344 of 3533, by robertmo3
the crush happens in regular dosbox in -vga mode too, so it is not related to rready/nor verite
Reply 1345 of 3533, by sharangad
robertmo3 wrote on 2024-05-07, 15:54:
only thing that has changed now is cpu usage jumped from 50% to 80% cart racing still unplayable though it got responsive after […]
though it got responsive after some time, cannot reproduce it cause it is crushing though
you can test on 4 cores without rebooting by starting command line and typing
start /affinity F rlauncher.exe
chart for more/less cores options are here
https://learn.microsoft.com/en-us/archive/blo … pu-affinity-set
you can verify which cores app uses while running in task manager ->details - right click on app - set affinity
you can change it live there
you can check/change priority there too
you can reduce cpu MHz speed in control panel - power options - power saver (between 50%-100%) (less than 50% will be still 50%)
The trouble with setting affinity is that video drivers can run on other cores. On a real dual or quad core, system resources uses the same cores.
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 1346 of 3533, by robertmo3
robertmo3 wrote on 2024-05-08, 00:52:
it also happens when run on rising engine
Reply 1347 of 3533, by robertmo3
sharangad wrote on 2024-05-08, 05:06:
that shouldn't matter with last two builds as they have free resources on every core
also one of your previous builds run on 3 cores only
Reply 1349 of 3533, by sharangad
Performance improvements galore ICR2 [ALT+X] running at 190 fps:
https://youtu.be/JYOOl2jb8p8
https://1drv.ms/u/c/5277ef8d4f2a9dcf/ERoFLdhn … 04VjSA?e=snfgMb
MD5: bdf68bed0d1e59170f7462a72ee24f9d
@robertmo3, I've tested this in quad-core mode and at it runs stably at 30 fps. I really really want to know how well it runs on your machine.
Reply 1350 of 3533, by robertmo3
robertmo3 wrote on 2024-05-08, 11:36:
robertmo3 wrote on 2024-05-06, 05:58:
robertmo3 wrote on 2024-05-05, 19:32:
yes whiplash intro in dma=0 has jerky sound
it looks it's caused by something else, although it doesn't happen on 2 cores 🤣
it is fixable by lowering dosbox cycles to 50%
(on 2024.05.06 release)
this trick is still needed
apart from that works fine
28 fps in cart racing, no lag => no jerks
Reply 1351 of 3533, by robertmo3
asdf53 tested rebel moon rising on rebel moon engine on v1000 and it has same artifacts as in the wrapper
Reply 1352 of 3533, by sharangad
robertmo3 wrote on 2024-05-08, 14:19:
Well that's a relief. Unfortunate, but a relief, for me at least.
Reply 1353 of 3533, by sharangad
robertmo3 wrote on 2024-05-08, 14:09:
this trick is still needed ------------- […]
What kind of framerate do you get in Whiplash with dma.
Reply 1354 of 3533, by sharangad
Oh BTW can run soda (with some menu corruption long has well Intel HD. This is a non-hyperthreaded dual core.
ICR2 intro runs fine on this @640x480, but the actual game s too slow.
Reply 1355 of 3533, by sharangad
If you set dosbox s sdl prioritisation to higher, higher do you get 30 fps in icr2?
Reply 1357 of 3533, by robertmo3
sharangad wrote on 2024-05-08, 14:35:
dma=0
cycles=45%
intro 60-130fps
game at start with cycles=105%
20fps when focus on game
40fps when focus on dosbox
dma=1
cycles=105%
intro 100-200fps
40fps when focus on game
80fps when focus on dosbox
Reply 1358 of 3533, by sharangad
robertmo3 wrote on 2024-05-08, 14:58:
dma=0 cycles=45% intro 60-130fps game at start with cycles=105% 20fps when focus on game 40fps when focus on dosbox […]
dma=0
cycles=45%
intro 60-130fps
dma=1
cycles=105%
intro 100-200fps
Drat! You don't get 60fps with dma.
Reply 1359 of 3533, by robertmo3
sharangad wrote on 2024-05-08, 15:12:
dma=0
cycles=45%
intro 60-130fps
dma=1
cycles=105%
intro 100-200fps
fix the mirror first 😉
