Reply 1382 of 1708, by sharangad
This is very very useful dude! Thanks! I think the mystery of where the firmware goes is now solved.
https://www.youtube.com/@sharangadayananda
Reply 1383 of 1708, by sharangad
robertmo3 wrote on 2024-05-08, 18:44:
i think any tr game never had game in background, in any version
I think @WhiteMagicRaven vids on YouTube had the game in the background while in game :
https://www.youtube.com/live/kbgDBQ5-UAY?si=t3kjATtTMxPJn0Uk
Reply 1384 of 1708, by sharangad
sharangad wrote on 2024-05-08, 18:45:
My bad. The mystery of where the framebuffer starts is now solved.
Just goes to how that I know next nothing about the card.
Reply 1385 of 1708, by robertmo3
here are all dos4gw.exe we found
i don't think any of them has some secret verite code hiden inside 😉
    README.TXT
    2.7 KiB
    9 downloads
    22.44 KiB
    dos4gw.exe
    374.34 KiB
    10 downloads
Reply 1387 of 1708, by sharangad
robertmo3 wrote on 2024-05-08, 18:52:
If not dos4gw, the actual game binary. The uc file is for the verite board not for the exe. The exe reads the file and loads it onto the gpu and runs it.
Reply 1388 of 1708, by sharangad
This might be of interest to you
https://github.com/sarah-walker-pcem/veritas
Disassembler for Rendition Verite V1000/V2000 RISC processor
veritas <microcode.uc>
Disassembly is output to stdout
Reply 1389 of 1708, by sharangad
Does the map render with whiplash with the cr uc file?
I think a minor modification should allow everything to work properly irrespective of firmware version.
Thanks @robertmo3. I might not believe the uc file contains the game ovl/dll files but the fact it drastically affects performance and the framebuffer address gives me something to work work with. You could be right, even if I don't think so at the moment.
Reply 1391 of 1708, by sharangad
robertmo3 wrote on 2024-05-08, 20:30:
no map
The view in the top left isn't the mirror, rather a mis-rendered frame.
All the buffer addresses are wrong, so double buffering doesn't work. I was very worried about the UC having such a massive effect. It's not. The addreses of textures/framebuffers are all wrong.
For instance with the CR UC with Whiplash, the front and back buffers are at:
V_FIFO_DISPLAY 0000E000
and
V_FIFO_DISPLAY 0008B000
With the original firmware:
V_FIFO_DISPLAY 00011000
and
V_FIFO_DISPLAY 0008E000
So the game literally POKEs the uc's program segment into VRAM and sets the frame buffer address to come after that.
V_FIFO_DISPLAY <address in hex> tells the Verite chip to set the visible part of the screen to start at address.
The reason you're getting better performance isn't because the UC file is working magic. What's happening is addresses are being miscalculated and the wrapper's doing less (or wrong) work, leading to a lower CPU load.
Reply 1392 of 1708, by sharangad
Ideally the wrapper should handle any uc firmware. It's not good enough to say it'll only work with the original firmware.
Reply 1393 of 1708, by robertmo3
that is camera on opponent HAL 9TH in the tunnel
in the camera you see BOB 7TH and BISHOP 8TH too
you can see HAL 9TH on the main picture in the tunnel too
as well as GORT 10TH and VOYAGER 11TH
you are 12TH before the tunnel
press f4 or f3 more to get to the mirror
Reply 1394 of 1708, by sharangad
robertmo3 wrote on 2024-05-09, 04:30:
that is camera on opponent HAL 9TH in the tunnel in the camera you see BOB 7TH and BISHOP 8TH too you can see HAL 9TH on the mai […]
The point is if I adjust the framebuffer address in the wrapper to handler that framebuffer, the rendering will go back to what it was with the original firmware. Give me 30mins and I'll get you two binaries to do just that.
Reply 1395 of 1708, by sharangad
Try this version of dosclient (place it in your rlauncher folder and run dosbox from from rlauncher):
https://1drv.ms/u/c/5277ef8d4f2a9dcf/ERUZeXxs … aMOPnw?e=bByg0R
MD5: d948930d33a251b31e73560093afd002
Try that with Whiplash with your CR UC file. See if the mirrors render. Please don't try it with the original firmware, I have no idea what'll happen with it.
Reply 1397 of 1708, by sharangad
robertmo3 wrote on 2024-05-09, 05:32:
with cr uc it is the same as it was before with original (same poblems)
with original uc intro problems are gone
I'm working on fixing them right now. The UC file runs on the actual hardware and with RReady/DR only controls the frame buffer address and nothing else and even that's by virtue of occupying space in virtual VRAM.
