Reply 1400 of 3238, by sharangad
Whiplash Mirrors, Mirrors, MIirrors!
https://1drv.ms/u/c/5277ef8d4f2a9dcf/EWQ5bIsF … h4lQPQ?e=yVWX11
MD5: 197aee10eb5edfe4d70b5b5586bc19a9
Youtube (poor demo, no F3/F4 toggling):
https://youtu.be/9icYJpsIqO4
Please use the original UC file!
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 1401 of 3238, by sharangad
It was while altering the framebuffer address for your custom dosclient that I noticed that Whiplash had a quad buffered primary surface. Knocked it down to 2 and hey presto, workng mirrors/camera.
Still no map! 🙁
Reply 1402 of 3238, by robertmo3
if you start cart game, exit it and start nascar, than nascar game behaves like whiplash: it shows more fps when focused on dosbox and shows less fps when focused on game
Reply 1403 of 3238, by sharangad
robertmo3 wrote on 2024-05-09, 07:26:
Dosbox Rendition increases Dosbox's main thread priority when launching a Speedy3D game. It doesn''t go back down on exit. The new level is above_normal. It can't go higher than this.
Reply 1404 of 3238, by robertmo3
i have it constantly set
priority = higher,higher
in dosbox.conf so it shouldn't affect me anyway
Reply 1405 of 3238, by sharangad
robertmo3 wrote on 2024-05-09, 07:58:
Not the process. The thread within the process. Within a process of a given priority, individual threads have a range of five priorities. Not all the threads in a program need run at the same priority.
Reply 1406 of 3238, by robertmo3
make Dosbox Rendition don't affect that
it should be set in dosbox.conf only
you can set it to higher, higher as default in dosbox.conf in dosbox source somewhere i guess
Reply 1407 of 3238, by sharangad
robertmo3 wrote on 2024-05-09, 08:08:
OK. Power's out at the mo. Grrrrr!
Reply 1409 of 3238, by robertmo3
got cgl rebel moon working, level 1 completed 😀
Reply 1411 of 3238, by robertmo3
i just didn't noticed OBJS.INI file in levels folder at first and it was crucial
Reply 1413 of 3238, by sharangad
https://1drv.ms/u/c/5277ef8d4f2a9dcf/EUyLL30r … __o3dg?e=d4GdvO
MD5: f2b1322948d815133355b6849ab6fc59
High res mirrors in Whiplash and the map. New generic render to texture codepath (ICR2 doesn't currently use this, but will eventually).
@robertmo3 I haven't changed the default config setting for priority yet (higher, higher), but will soon/
Whiplash in action:
https://youtu.be/N9hH2KPPtyU
Reply 1416 of 3238, by robertmo3
rebel moon rising:
i think verite has problems with rendering pictures whose higth is not multiplication of 32 pixels/the gifs also change higth between frames/ also may be too high resolutions
(should be easy to fix by resizing them) (but maybe you can fix it on your side too in the application so it accepts them)
rebel moon cgl:
this looks harder:
some doors have corrupted textures, but other doors that use same texture look fine
i guess maybe doors are of different sizes and while rmcgl accepted that, rmverite requires precise sizes of 3d models of doors
doors/elevators (every walls that move vertically) (not that i seen horizontally moving ones)
I guess their .3de files could be fixed 😉
Reply 1417 of 3238, by robertmo3
rmcgl
Reply 1418 of 3238, by robertmo3
rmcgl
