Reply 1460 of 1774, by robertmo3
are you sure you are no longer affecting priorities in any way?
Reply 1461 of 1774, by sharangad
I am. I didn't lower dosbox s main thread s priority, yet.
https://www.youtube.com/@sharangadayananda
Reply 1463 of 1774, by robertmo3
in the past i said i use higher to fix everything
so you changed it
and it broke everything
so i asked to revert that, only that, to compare
and you didn't
Reply 1464 of 1774, by robertmo3
just properly remove that feature, make a build, and i will check that
no other changes, just that one feature, nothing else
Reply 1465 of 1774, by sharangad
K I have a build which does just that (and mouse changes. Nascar should have a much more responsive mouse. )
Will post it once I get back to my desk.
Reply 1466 of 1774, by sharangad
A Verité owner with a copy of ICR2:
Could you try these custom tracks and see if they work?
"Here are some custom tracks I tried:
Detroit 1991 by me (https://icr2.net/forum/showthread.php?tid=133 … =13136#pid13136) - "Problem loading track"
Indianapolis 1992 by Pavel (https://icr2.net/forum/showthread.php?tid=1419) - "Insufficient memory to load track"
Meadowlands by Pavel works except for the texture issue I highlighted above.
Nashville by me (https://icr2.net/forum/showthread.php?tid=135 … =11743#pid11743) - it works until the game crashes along the return trip across the bridge
The Lola1990 and Reyn1996 carsets do not load - error message is "Not a valid carset""
Post in thread 'IndyCar Racing II: The Rendition Experience' https://community.racesimcentral.net/threads/ … 1837/post-44802
Reply 1467 of 1774, by sharangad
@robertmo3, sorry for the delay. I've been slapped with a working time directive by my family, which stops me from working on RReady on weekends. I'll have to sneak time in whenever possible today.
Mouse changes + all prioritization changes disabled:
https://1drv.ms/u/c/5277ef8d4f2a9dcf/EdymhdqJ … ZXrbdQ?e=fMDGmE
MD5: eecaccdd6480c29b4ef532d9475700a3
Let me know what you find.
Reply 1469 of 1774, by sharangad
Did that work @robermo3?
is your theory correct?
Reply 1470 of 1774, by robertmo3
looks like it doesn't make any difference
anyway some things i noticed:
i turned off antivir stream updates that can make updates even every 3 minutes and they are followed by installer worker and windows update that occupies whole core for a few minutes.
other thing is that
priorities =lower,lower
make games not crush at all
priorities =normal, normal
almost don't crush too
priorities=higher,higher
crushes a lot (in cart racing and whiplash) (especially on 2 cores)
there is also that:
panels on
in whiplash gfx config reduces fps a lot
Reply 1471 of 1774, by sharangad
That's good to know. So you were experiencing random crashes as well.
I need to try this on Sandy Bridge i7/hd 2000. Crashes instantly at startup. I take it framerates are lower with this setting?
What's the cpu load with this, higher or lower? I've got some sleep(0)/yields in there when the threads don't have any work. That should allow other tasks to use the cpu for a scheduling period (tiny amount of time)
Reply 1472 of 1774, by sharangad
I'll make the upscaling mirrors toggleable, but your gpu should be able to handle it without breaking a sweat.
Reply 1473 of 1774, by sharangad
Also in Cr the menus are really slow right? Need to profile that at some point.
Reply 1474 of 1774, by sharangad
Priorities=lower, lower
Crashes instantly on my uhd620/i3 8 series laptop.
Reply 1475 of 1774, by robertmo3
memsize = 16
makes nascar work in 25fps in win8.1
30fps in win11
and nascar doesn't crush with that
i guess this may also solve tracks loading problems
Reply 1476 of 1774, by robertmo3
got 30fps in win11 in cart racing (over 60 with alt+x)
Reply 1478 of 1774, by sharangad
robertmo3 wrote on 2024-05-12, 20:38:
memsize = 16 makes nascar work in 25fps in win8.1 30fps in win11 and nascar doesn't crush with that i guess this may also solve […]
memsize = 16
30fps in win11
I was wondering why that slowed down all of a sudden. Rlauncher may need profiles for dosbox-rendition. Cfg.
