Reply 1560 of 3318, by robertmo3
at first look nothing has changed in tr 😉
robertmo3 wrote on 2024-05-18, 07:11:at first look nothing has changed in tr 😉
That's in the mansion will test it.
My testing so far has been in actual gameplay.
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
I think this is the handiwork of my fast custom bitset.
new game
@robertmo3, can I have your save?
The mansion works for me.
robertmo3 wrote on 2024-05-18, 08:13:new game
As does the fist level.
I think your intel CPU doesn't like my custom bitset.
sharangad wrote on 2024-05-18, 08:19:robertmo3 wrote on 2024-05-18, 08:13:new game
I'll switch back to std::set to see if it fixes it.
maybe check it on your intel machines first
See if this fixes your tomb raider issue:
https://1drv.ms/u/c/5277ef8d4f2a9dcf/EQdJiM7O … Rrsdvw?e=E3mQSU
MD5: 26a713fa807d9cecf55f0674770788d5
robertmo3 wrote on 2024-05-18, 08:35:maybe check it on your intel machines first
I've so far only tested CR on my intel machines and 2 of them crash on the second frame. WIll try now and the other one is being used.
doesn't change anything
i use default dosbox.conf
and default Rendition.cfg
TR1 Works on Sandy Bridge HD2000.
CR crashes at startup on this.
robertmo3 wrote on 2024-05-18, 08:45:doesn't change anything
Can you zap teh dosbox folder and re-create it? With the binaries.
Also does the last known good version still work?
Also does software rendering still work?
12 is still fine
13, 15, 18 have problems
same in win8.1 and win11
same with nvidia and integrated one
my guess is maybe higher cpu requirements makes game corrupt in the loading process, cause when i go to the swimming pool only textures are the ones of water surface and larra, rest is completely black
robertmo3 wrote on 2024-05-18, 09:18:12 is still fine 13, 15, 18 have problems same in win8.1 and win11 same with nvidia and integrated one […]
12 is still fine
same with nvidia and integrated onemy guess is maybe higher cpu requirements makes game corrupt in the loading process, cause when i go to the swimming pool only textures are the ones of water surface and larra, rest is completely black
Ah ok. Hang on I've got just the thing for you. It'll be a bit slower, until I optimise it.
https://1drv.ms/u/c/5277ef8d4f2a9dcf/EYNKkaJZ … AKkGfA?e=E1MJaN
MD5: d4b768e8a9d91ad65236f2b6fd1d4b94
See if this makes a difference. It'll be a lot slower.
doesn't make difference
it looks hot thread attracted spambots 😉
robertmo3 wrote on 2024-05-18, 09:33:doesn't make difference
With the last version use this.
Also try other priorities like higher,normal and higher, higher.
I did tweak memwrites earlier.
robertmo3 wrote on 2024-05-18, 09:42:it looks hot thread attracted spambots 😉
AAargh!
