First post, by naujoks
I have a socket 7 board that's stuck in reset: the reset LED on the POST card is constantly lit.
https://theretroweb.com/motherboards/s/fic-pa-2007
What could I try to get the board out of reset?
Reply 1 of 3, by dominusprog
Have you connected any peripherals? The issue can be caused by a bad BIOS.
OPTi MAD16 / Creative Vibra16XV ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 2 of 3, by kotel
naujoks wrote on 2024-05-18, 07:10:
Did you set the jumpers correctly? Also, did you check if your CPU is supported?
Always has the weirdest issues happen, and always is all alone with them
Reply 3 of 3, by Nexxen
Look, it's always good to post pics of the original board.
Have you checked:
- cpu voltage at power mosfets or bjt?
- tested with another cpu?
- as suggested tried a different bios chip + version?
- did you use a POST card in ISA also?
- probed all the crystals? clock generator?
- tried cycling a bunch of times power on off?
- did you inspect the board for any physical damage?
... just some random stuff
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
