Reply 1600 of 3485, by sharangad
robertmo3 wrote on 2024-05-19, 10:16:
using verite.dll and redline.dll from 12 makes tr look like 12
13, 15, 18 work just with dlls from 12
i don't have to change dosclient.exe for tr
Phew!
That's a relief.
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 1601 of 3485, by sharangad
https://1drv.ms/u/c/5277ef8d4f2a9dcf/ER6vSSAb … fXiAtQ?e=wJDYZr
MD5: 0c6a27cb92d5a31ece53501286d69287
@robertmo3: See if this fixes your tomb raider texture problem
Other fixes:
- Tomb Raider chroma keying now works
- Tomb Raider Eidos splash screen should be free from corruption.
- Whiplash performance is now back to normal
- Cart Racing high resolution mirrors. Part of the mirror isn't being chroma keyed out. This will be fixed later.
- CR textures in Rendition HQ levels should disappear less when high detail mirrors are in use ([ALT+M]). This appears to be a CPU load dependent switch to black. The Rebel Moon black texture also needs a fix.
Reply 1602 of 3485, by robertmo3
doesn't fix tr
Reply 1604 of 3485, by sharangad
robertmo3 wrote on 2024-05-19, 13:31:
doesn't fix tr
This is weird. I haven't committed any code for RReady in a long while and I'm not entirely sure which change causes your problem. But it works on a Sandy Bridge i7. I'll test it on my other Intel machines including a Haswell dual core.
Reply 1605 of 3485, by robertmo3
how to find it should be very easy:
you have let's say 100 changes, so you try change 50th change first, and it either fixes or not
if it fixes than you try 75th change
if it doesn't fix than you try 25th change
every test throws away half of changes left,
just always check the middle change next (to save time)
that's how i do it when looking for regressions in the code
(and also testing any numeric changes in the code too, when trying to find the exact value that changes something)
Reply 1606 of 3485, by robertmo3
it that is just one big change and you don't have the order of changes
then you just revert half of changes and they either fix or not
and then you just test half of the left ones like before
Reply 1607 of 3485, by robertmo3
this way 100 changes are detected in only 7 tests
Reply 1608 of 3485, by robertmo3
if you have twice more changes that will be just one test more 😀
Reply 1609 of 3485, by sharangad
Tomb raider runs perfectly on my Haswell dual core and the i3 uhd 620.
I'll test the Sandy Bridge machine in a bit.
Can you test it on integrated graphics to see if it makes a difference?
Reply 1610 of 3485, by sharangad
Also is your tomb raider exe called tombren.exe?
If it isn't then that's the problem.
The older version applied byte level change detection for all dos apps. The newer version does not.
Reply 1611 of 3485, by robertmo3
all 5 versions of tomb.exe files provided by someone here in the thread were all called tomb.exe
Reply 1612 of 3485, by robertmo3
here
Reply 1613 of 3485, by sharangad
robertmo3 wrote on 2024-05-19, 14:35:
The binary available on this site under rendition game updates is called tombren.exe. I'm guessing that's what it called in the final release.
I'll add support for tomb. Exe as well. Tomorrow...
Reply 1614 of 3485, by sharangad
robertmo3 wrote on 2024-05-19, 14:38:
here
I'll add tomb.exe as a supported name.
Under the downloads on this site there's a zip file of final game binaries for rendition.
Reply 1619 of 3485, by sharangad
This release should be able to handle both tomb.exe and tombren.exe:
https://1drv.ms/u/c/5277ef8d4f2a9dcf/ESSqzIvA … uYdnyg?e=5hKHq7
MD5: 477f9af8286d04534a73087a377a9950
ICR2 appears to have picked up a strange stride issue with some textures.
