Voodoo locked at 640x480
First post, by Kouwes
In another thread here I asked about my AMD K6-2 533 system that worked fine but suddenly wouldn‘t go higher than 640x480. Card is a Voodoo 3 2000 PCI. As suggested, I ordered new caps for that board, it had Tayeh caps.
Haven‘t replaced them yet so I can‘t tell if it’s working now.
But I have the same problem with another PC. Always worked fine but when I switched it on yesterday the resolution in Win98 was at 640x480 and no way to change that. I tried my Panasonic CRT, didn‘t help.
Ah, the PC has a Voodoo 5 5500 AGP. So I tried a Voodoo 3 3000: same problem.
So I guess the MoBo has a problem?
The caps all look ok, and yes I know that doesn‘t say much.
Board is a P3B-F by the way.
Seems it needs new caps all well then? Any thoughts?
PSU is ok, 12.2 and 5.1V on the molex connectors.
Reply 1 of 6, by rasz_pl
what does that mean exactly? system crashes? no other resolutions showing up? is that all in windows?
Reply 2 of 6, by Kouwes
That means 640x480 is the only resolution setting available in Win98. Can‘t do 800x600 or whatever.
Reply 3 of 6, by rasz_pl
at 16 colors or any depth you want?
did you use same monitor cable for both monitors?
what monitor is installed in windows? http://ps-2.kev009.com/pcpartnerinfo/ctstips/3ff6.htm
Reply 4 of 6, by Kouwes
Same cable, yes. But the cable works just fine with any other PC I have.
Like I said, the Win98 desktop resolution was set at 1600x1200 when I used the PC the last time - which is like several months ago.
I usually use an HP LP2065, no problems with it. Tried another PC with Win98 and 1600x1200 worked fine so no problems with the monitor and the cable I‘d say.
Reply 5 of 6, by rain
It look like driver issue, which directx version you use
Reply 6 of 6, by Kouwes
rain wrote on 2024-05-20, 12:10:
Not sure to be honest but then again, on that PC I only play games that support Glide - hence the Voodoo 5. Also, the desktop resolution has nothing to do with directx.
As for the driver: got it from Phil‘s site and I have been using the PC with the same setup for years.
