First post, by ux-3
I inherited this hardly used small µATX SS7 board decades ago: https://theretroweb.com/motherboards/s/bcm-in530
I recently downgraded the bios to an early version which allows to disable onboard cache. Which allows to use fine speed settings with mmx CPUs.
Here is the crunch: The board comes with SIS 530 AGP VGA as well as ESS Solo-1 onboard. It allows for a total of 3 expansion cards, one of them can be ISA, 3 can be PCI.
The Solo-1 is often considered to be one of the best PCI sound cards for DOS games. I tried it with several titles, they all work fine.
The SIS530 AGP graphics delivers real 3D as slide show only. But then, the chip only has to get DOS and 2D done. The video signal is nice and steady. Several DOS titles recognized the higher VESA resolutions out of the box. So it might be good enough for DOS.
CPU can be PentiumMMX 233 or AMD K6-2 500. Board has 2x USB, available for front connector. The board came with win98SE.
With only 3 card choices available, this is tough. This is the selection to consider:
(NEC XR385 daughterboard)
Diamond Viper 330 PCI Riva128 (not really, if onboard does the 2D/ DOS job too)
Diamond Monster 3D (Voodoo1) (booked)
2x Diamond Monster 3D II (Voodoo2 optional SLI) CPU is too weak
Soundblaster 32 AWE 8MB + NEC XR385 (current choice! It is the CT3980, it is about the best AWE32 I could place here)
Soundblaster 64AWE (Gold) (no wavetable)
SBpro Clones (ESS, Yamaha) + NEC XR385
USB 2.0 PCI card
Ethernet PCI
Given that this machine is to cover DOS, I would like to bring in a DOS wavetable. Regarding hanging notes and DMA clicking bug, I wonder if I could use the Solo-1 for digital and the 32AWE just as wavetable adapter at 330? That would hopefully evade those bugs. Later games could use SB16 or AWE settings.
Is there something to be gained by using one of the two SB PCI cards?
Any ideas or comments?
My own PC biography had a large gap from P166 to P3-500 because I had no time in between. So I kind of missed the early 3D age. While the focus of this machine should be on DOS, I certainly wouldn't mind if it could cover up to Win98.
Retro PC warning: The things you own end up owning you.
