Reply 27660 of 31469, by PcBytes
Teodor wrote on 2024-05-29, 05:20:
Last Saturday I became the proud owner of this GA-6VX7-4X rev. 1.2, it was a flea market find. See something missing? Yup, almost all the caps and the chipset heatsink were ripped off the board. Man, someone must have been in bad need of Aluminum. Anyway, I would very much want to revive the motherboard, but I don't know the caps values. I found the board on Retro Web, but from the pictures I can't distinguish anything. I watched some YouTube videos but without much luck. I guess the big green capacitors are 1200uF/6.3V but the rest remain a mystery to me. Can anybody be of help? I mean, maybe you know where I can find the capacitor list, or you have the same board, and you are able to see the values on the caps. It would be greatly appreciated.
These were the values off my 6VX7B-4X. Mine was literally the same board as yours except no PPGA support.
CPU caps - 1200uF 6.3v
everything else is 330uF 25v for whatever reason - you can use 1000uF 6.3v or 10v.
Reply 27661 of 31469, by NHVintage
Thanks for the PCChips suggestions, all. I tried the chip press and no dice on any of them (or any combo of chips being pressed). I don't have an EEPROM reader or an oscilloscope, so I can't check with those. I was going to try swapping BIOS chips with another board (it wouldn't boot but it would do SOMETHING I figure, letting me know that's the problem) but sadly, I don't have another board with that same chip type. Naturally.
I decided to pull the BIOS chip and reseat it to see if there was an issue there (the contacts are pretty clean both on the socket and the chip) and while I had the chip out I powered up and noted the activity (such as it was) on my diag card was unchanged, so that suggests to me a bios issue. I noticed it was easier than expected to take the chip from the socket, suggesting someone maybe swapped chips or otherwise played with it, possibly. So, I guess its time to get an EEPROM reader. 😀
EDIT: Anyone got a suggestion for a good EEPROM reader for a windows 10-11 machine? They ain't cheap and would prefer to get one that someone's actually used. Thanks!
Reply 27662 of 31469, by Teodor
PcBytes wrote on 2024-05-29, 09:21:
These were the values off my 6VX7B-4X. Mine was literally the same board as yours except no PPGA support. […]
Thank you kindly for your answer. Now I must check in my capacitors stash if I have these values, or else I will place an order online. Many thanks!
Reply 27663 of 31469, by PD2JK
Thermalwrong wrote on 2024-05-28, 22:20:
PD2JK wrote on 2024-05-28, 16:21:
Fiddling with some LMSI stuff, got it working. It reads burned stuff as well.
So cool 😀 Is that the one with the non motorised pull out tray or is it the later one, which I think might be 2x speed? Here's mine when it was set up, it should really go in a case sometime: Re: Where do you attach your CD-ROM?
Yeah great hardware to play with, it's the later one. CM 260 controller with Philips CM 206 motorized drive. I got a PAS16 with LMSI on board on the way, because I don't have any digital sound yet.
You got a nice collection there. 😀
has all kinds of stuff
Reply 27664 of 31469, by Teodor
NHVintage wrote on 2024-05-29, 12:10:
Hi! Maybe the "CH341a Mini Programmer" would be a cheap alternative. You can order it online with lots of adapters. There are many clips on YouTube and may require a Volt-mod for 3.3V. Adamant IT showed how to do this Volt-mod on his YouTube channel. Some soldering skills are necessary for the mod. I used it a few years ago to read a BIOS chip from a GA-H61MA-D3V. I remember I successfully read the BIOS, but I had to desolder the chip from the board and solder it on some adapter to do the read. On some motherboards I guess there may be a pin header allowing to read and write the memory chip in-circuit.
Reply 27665 of 31469, by Joseph_Joestar
My PS4 Pro was getting loud in some demanding games like Shadow of the Tomb Raider, so I opened it up and cleaned the fan. I do this about once a year anyway, and it did slightly reduce the noise.
What helped more, in my particular case, was raising the PS4 Pro slightly from the table that it's resting on. To do that, I used four rubber erasers (around 2 centimeters thick) and placed them below the console, one under each corner. It seems like the bottom of my PS4 Pro gets pretty hot, so any extra airflow there helps with reducing the fan noise. The rubber erasers also dampen the vibrations a bit, which is an extra bonus. I'm pretty happy with the end result.
My retro builds
Reply 27666 of 31469, by PcBytes
Teodor wrote on 2024-05-29, 18:48:
For those older mainboards a TL866 is required - CH341A can't handle any other chips than 24, 25 and 93 series chips.
Reply 27667 of 31469, by BigDave
It's 1998, and just finished setting up my new Packard Bell Club 40 from Dixons, and exploring all the delights of the pre-installed 'Club College' software pack, before setting up a NetP@ss account for free 56k dial up internet access.
The attachment IMG_20240530_092440~2.jpg is no longer available
OK, well it's all part of the Packard Bell experience I never had, and now in my 50s, and after 15 months trying to restore to as near complete and original, I finally get to enjoy it, thanks to a lot of help from you guys!
I posted everything in the Post Your Packard Bell Computers Here! thread.
Re: Post your Packard Bell computers here!
Reply 27668 of 31469, by Teodor
PcBytes wrote on 2024-05-30, 08:26:
Sorry for the confusion. I was under the impression that is a motherboard for a Windows 10 system, now I realize that the programmer must run on the said system. My mistake. Sorry!
Reply 27669 of 31469, by badmojo
BigDave wrote on 2024-05-30, 09:08:
It looks fantastic! And Rally Championship, what a great game 👍
Reply 27670 of 31469, by Minutemanqvs
Repo Man11 wrote on 2024-05-23, 19:46:
Minutemanqvs wrote on 2024-05-23, 19:24:
Repo Man11 wrote on 2024-05-23, 18:59:
I like it. I do have a question: is the printer port disabled in the CMOS settings? I recently had an issue installing Windows 2000 on a board with a BIOS from 2002 and it blue screened because the BIOS wasn't ACPI compliant. I did a search, and it turned out that disabling the printer port caused this error during setup, and enabling it solved the problem.
Ah yes, I disabled printer and serial port in the BIOS! I will try to re-enable it. Now the BIOS only reports "APM" support, and not ACPI.
I had never heard of this issue until a little over a week ago.
A late reply...
So I tried to switch the LPT port on with BIOS F7 (the latest listed on Gigabyte's website) and FAa (the latest beta bios from TRW) but the BIOS summary screen still shows "APM, SMI" instead of the expected ACPI. And I don't dare to change the computer type from "Standard PC" to ACPI computer in my device manager as I'm pretty much sure it will fail and I'll need to reinstall everything. So I'll just live with it, it's perfectly fine. But thanks for the tip!
Searching anything Nexgen, PM me if you have one. Also ATI Rage 128 PCI cards.
Reply 27671 of 31469, by ssokolow
I just installed a ps2x2pico firmware update that has fixed all the Win98SE/t5530+USB KVM compatibility bugs I discovered and finished resolving the two big Fatal Error 0E blue screens for the HP t5530 I repurposed as a Win98SE PC and KVMed onto my triple-head daily driver's left monitor for leisure breaks. 😀
They were "Use the VIA USB 2.0 drivers, not NUSB... or at least downgrade USBHUB20.SYS" and "Uncheck Automount in DAEMON Tools if you're mounting ISOs off a network share or you risk having something try to read the virtual CD's icon from autorun.inf on boot before VREDIR.VXD has finished initializing".
The attachment screenshot.png is no longer available
(Yes, WinZip Self-Extractor non-personal-edition is in the screenshot because Corel getting back to me and agreeing to downgrade a freshly purchased WinZip Self-Extractor 4 license to a key for the 2.2 installer on their "no-longer-supported downloads" page is still the retro-hobby thing that makes me happiest. Eeeeeee! I'm actually licensed to distribute retro-authentic self-extractors! I wanted a copy of that thing (that I trusted to not embed signs of a keygen'd serial in the built self-extractors) so much as a kid!)
I also ordered a couple of other thin clients to experiment with. (An Igel 3/2 and a Wyse Cx0.)
Now I just need to...
  • figure out why Timon & Pumbaa's Jungle Games triggers a blue screen that silences the audio at the start of a game when using the DirectX-compatible v650 WDM drivers
  • Remember which video codecs I installed beyond the Combined Community Codec Pack last time I installed this thing
  • Install my copies of Borland Delphi 1 and 2 and Open Watcom C/C++ 1.9
  • Image or dig up my backups of my 3D Ultra Pinball CDs, put them on \\monolith-tng\retro\CDs, and install them.
  • Set up WinSCP for backing up save files
  • Take more rsync backups using Damn Small Linux along the way to serve as system restore points
EDIT: Dammit. I just realized I should have had that screenshot playing the 3x3 Eyes AMV in my WinAMP plugin test playlist. Even more Win98 nostalgic... oh well. I'm not going to change it now.
Internet Archive: My Uploads
My Blog: Retrocomputing Resources
My Rose-Coloured-Glasses Builds
I also try to announce retro-relevant stuff on on Mastodon.
Reply 27672 of 31469, by BigDave
badmojo wrote on 2024-05-30, 11:52:
Thank you.
Rally Championship is a great game, and very nostalgic, as it's the first PC game I ever bought (actually, I think it was a present) way back in about 1997. Works a treat.
Reply 27673 of 31469, by bofh.fromhell
Thought i could help you so I dug out the system with my P3 Gigabyte board.
Turns out it has a GA-6VXC7-4X, which is at the same time very similar spec-wise, but also completely different -.-
Reply 27674 of 31469, by ubiq
Put a K6-2 400MHz in my Socket 7 AOpen AX5T-2. 400MHz with 66MHz bus and 2x multiplier, thank you! 😎 It worked just fine, except the AX5T-2's rudimentary voltage regulation was totally not up to the task, and the single mosfet immediately started cooking itself.
The attachment IMG_1297.jpeg is no longer available
I'd recently built a couple Necroware VRMs and thought hmm... is there anyway I can use one here? And so:
The attachment IMG_1295.jpeg is no longer available
Since I'm a dummy who barely knows what he's doing, I spent a lot of time with my multimeter checking voltages and pathing things out before doing this, but anyway:
The attachment IMG_1296.jpeg is no longer available
I desoldered the mosfet, and jammed the necroware VRM output voltage down a couple specific jumper headers.
It works! 👍
Edit - decided it was good enough for me and put it in the case:
The attachment IMG_1298.jpeg is no longer available
The attachment IMG_1300.jpeg is no longer available
Reply 27675 of 31469, by zuldan
My Yamaha MU80 arrived today. Not happy with the eBay seller. They cut the metal leg holding the old battery to the PCB then wrapped some electrical tape around it. They then soldered some wires to the PCB and a CR2032 battery holder (wrong vertical one) and used electrical tape to hold that against the side of the case. The battery they installed was old, running at 2.9v. So now they left 2x CR2032 batteries in there to leak overtime 🤣.
The attachment IMG_5303.JPG is no longer available
The attachment IMG_5302.JPG is no longer available
The attachment IMG_5304.JPG is no longer available
The attachment IMG_5306.JPG is no longer available
Luckily no damage was done. I desoldered everything and installed the correct CR2032 holder. She's working perfectly!
The attachment IMG_20240531_102217.jpg is no longer available
Reply 27676 of 31469, by Teodor
bofh.fromhell wrote on 2024-05-30, 16:23:
Could you, please, tell me the values and the voltage of the caps between the PCI slots (the ones between the PCI and AGP slots I know they are 1000uF/10V). I guess at least this portion of the board is the same. Thanks!
By comparing the images of your board and my board (the picture found on The Retro Web) I believe that the two capacitors between the memory slots and floppy disc connector are the same (but I don't know the values). TC16 and TC17 between the Northbridge and SW2 DIP switch look to be the same too. The last ones I suspect they are 1000uF/10V, but a confirmation would be good. TC12 and TC8 look similar too, could you tell me their values? They are situated next to the AGP slot.
Reply 27677 of 31469, by zuldan
ubiq wrote on 2024-05-30, 18:20:
It works! 👍
Very impressive. Well done!
Reply 27678 of 31469, by appiah4
zuldan wrote on 2024-05-31, 04:37:
My Yamaha MU80 arrived today. Not happy with the eBay seller. They cut the metal leg holding the old battery to the PCB then wra […]
Never saw a cr2032 leak. Like, ever. Aside from looking ugly that seems like a reasonable mod to me..
Reply 27679 of 31469, by zuldan
appiah4 wrote on 2024-05-31, 05:35:
Very very old ones can. They can become nasty Have you opened your SC-55 to check the battery inside?. I got rid of them on all my Roland devices. One had started leaking but hadn't done any damage yet.
On another note, I ordered two X2GS 's yesterday. Both with your preset installed. You did a fantastic job with it!
