Reply 27660 of 30988, by PcBytes
- l33t
Teodor wrote on 2024-05-29, 05:20:Last Saturday I became the proud owner of this GA-6VX7-4X rev. 1.2, it was a flea market find. See something missing? Yup, almost all the caps and the chipset heatsink were ripped off the board. Man, someone must have been in bad need of Aluminum. Anyway, I would very much want to revive the motherboard, but I don't know the caps values. I found the board on Retro Web, but from the pictures I can't distinguish anything. I watched some YouTube videos but without much luck. I guess the big green capacitors are 1200uF/6.3V but the rest remain a mystery to me. Can anybody be of help? I mean, maybe you know where I can find the capacitor list, or you have the same board, and you are able to see the values on the caps. It would be greatly appreciated.
These were the values off my 6VX7B-4X. Mine was literally the same board as yours except no PPGA support.
CPU caps - 1200uF 6.3v
everything else is 330uF 25v for whatever reason - you can use 1000uF 6.3v or 10v.
