Reply 2180 of 2508, by feipoa
- l33t++
pshipkov wrote on 2024-06-02, 06:31:feipoa wrote on 2024-06-02, 02:51:If I need to run the BL3 at 33 or 40 MHz FSB, there's faster boards than the YB.
Which ones you are thinking about ?
At 33 MHz, the Daewoo Panda-based board will beat the PEM-4036YB due to the use of VLB graphics. Also, my BIOS has been modified to allow for adjustment of the ISA bus speed. The SiS Rabbit at 3x33 or 2x40, with ISA graphics, should also match or beat the PEM-4036YB. The Rabbit has the added bonus of being a pure 386 board, that is, not a board containing a chipset which is a 386/486 hybrid. This matters to some. The results will likely be different at 50 MHz FSB, but that's out of the range of the 4036YB.
pshipkov wrote on 2024-06-02, 06:31:feipoa wrote on 2024-06-02, 02:51:Did you try YB with BL3 at 2x45? Or it failed even with 1x45?
The board itself is struggling. CPU clock multiplier is not a factor.
Although I'm quoting the CPU clock, I'm not intending to emphasise it. However, on some boards, success at 1x doesn't necessarily translate into success at 2x, but I'm not talking about that with these DTK boards. I can emphasise FSB spends only if it is clouding the exchange of information.
pshipkov wrote on 2024-06-02, 06:31:feipoa wrote on 2024-06-02, 02:51:I played again with the Gemlight at 50 MHz. Even with DRAM at 2 ws, it will not POST successfully. Perhaps the key is your 100 MHz crytals? I remember you saying that this could matter when on the edge. What is the branding on yours? Mine have ECLIPTEK ECH11, 100.00M.
So far all crystals worked fine at up to 100MHz. At least i didn't notice difference between them.
Story changes at 110MHz.
What brand and model of crystals are you using at 100 MHz?
pshipkov wrote on 2024-06-02, 06:31:Tested both. Wanted to see if they behave differently to determine which one to keep. They functioned the same. One of them went […]
feipoa wrote on 2024-06-02, 02:51:I already tried all sorts of SIMMs, 4 modules and 8 modules. 50 MHz isn't happening for me, SRAM or otherwise. Also tried 6.67 MHz. Is it possible that you tested up to 50 MHz on just one of your Gemlight boards (the one that was sold online) and the secondary board (the one I received) wasn't confirmed up to 50 MHz? I'm thinking that certain chipsets cannot cope with 50 MHz. I did try a heatsink/fan on the chipset though.
Tested both. Wanted to see if they behave differently to determine which one to keep. They functioned the same. One of them went to Ebay, the other one is with you.
I am really very puzzled that you are struggling to get it going at 50MHz. What can be the problem ? I assume FPU is not inserted, right ? Most of them don't like 50MHz very much.
So at 50MHz no lights at all ? Or POST hangs ? Or boot hangs ? Where exactly it stops ?
Maybe you really collected all the bad memory modules on the planet, but i doubt it. : )
Unlikely.
Yes, I removed the FPU for most of the testing. I think I had put the FPU back when I tested the SCSI 6.67 setting though. The outcome is either the system hangs just after the SCSI BIOS completes (just before boot attempt), or I get "no command interpreter" when booting. The longer the system had been on, the quicker it will hang. For example, if it had just been powered on for the last 5 minutes, it will even freeze inside the BIOS. Implies a heat dependency. It was 23 C in the office (at the door) when I ran these tests, although it was closer to 26 C at the motherboard. My desk lamp has one of those damned heater bulbs that require a UV filter to prevent skin cancer. its the last non-LED bulb in our house. I had replaced it with an LED alternative, but that guy burned out after 3 months, so the halogen went back in. Anway... What was the temp when you tested? The main difference in our setups are the RAM and that fact that I always use PS/2 mice via a KBC adaptor. While I could remove the PS/2-KBC, there's no situation in which I'd accept a 386 board at 50 MHz without a PS/2 mouse. It would be the black sheep in my pasture. We all have our requirements.
pshipkov wrote on 2024-06-02, 06:31:feipoa wrote on 2024-06-02, 02:51:I'll have to try this. Are you holding down F2 while opening Notepad with the mouse left-click? Or do you already have Notepad open with some text on it, and only then start to hold down F2 and wait? Wait how long? Are you still holding down F2 while trying to close Notepad with the mouse? Must you open the saved file to witness the corruption? Or is there a corrupt file on the HDD that Scandisk picks out?
You can try it in Windows Commander, Norton Commander, or Dos Navigator.
F4 to open file for edit. Then hold F2 for i don't know - 30 seconds to a minute and see what happens.
You lost me here. You were talking about Notepad and F2 (save in loop), but then bring up Windows/Norton/DOS Commander. That's like Ztreewin, but for DOS right? If so, I don't use any of those. Do your instructions not apply to use in Windows 3.1?
pshipkov wrote on 2024-06-02, 06:31:What i meant is that when overclocked some SCSI adaptors seem to freak-out the keyboard controller or something like that. In tu […]
feipoa wrote on 2024-06-02, 02:51:For your other test, you just hold down ENTER while on the Windows 3.1 desktop and move the mouse around? The test passes if apps that the mouse pointer hoovers over aren't opened, and also nothing else flying around?
In turn the keyboard controller keeps spamming the system with keys presses, including the Enter one.
As a result any context sensitive actions get triggered.
When in Windows if i select an icon it immediately invokes its function. If i move the mouse over buttons or other active elements they get triggered.
It is a zoo. Very dangerous one because you can easily mess-up windows configs and the content on disk. Quickly learned that Wolf3D is 100% indicative of the problem, so stopped double checking in Windows. Anyway.
I have only run into this a few times with extreme edge-of-stability conditions. It is good to know that Wolf3D offers an easier test alternative, but I don't normally run Wolf3D. Are you running Wolf3D with EMM386 enabled, or without EMM386 but with autoexec/config bypassed (to save conventional memory)? When I run Wolf3D, I think I normally run it with the config/autoexec bypassed, unless I need to setup some registers first.
