Reply 53240 of 57143, by PcBytes
- l33t
Nyeheheh 🤣
Nyeheheh 🤣
Can somebody help me understand this.
Today I picked up a flex ATX PSU, it's a replacement for a dead one on an OEM P3 system. I made sure to choose one with stronger 5v and 3.3v rails than the old one.
So the rails are thus:
+5v = 12A (60W)
+3.3v = 9A (39.6W)
but the label on the PSU says "MAX OUTPUT POWER 220W. (+3.3V + 5V =60W)
Why would it be just 60w over two rails that go higher than that?
90s PC: IBM 6x86 MX 233MHz. TNT2 M64. 256MB RAM, 2GB CompactFlash.
Boring modern PC: i7-12700, RX 7800XT. 32GB/1TB.
Fixer upper project: NEC Powermate 486SX/25. 16MB/400MB.
From "The CPU Unicorns" series, a nice AMD k6 black top engineering sample. Alive and working, more tests later 🥳
Retro builds & sandbox
IBM XT 5160 | 286 | 386 | 486 | S4 SI5PI AIO & S4 Batman + P60 SX828
S8 & PPro 200 | SS7 FW 5VGF & Asus P5A & AOpen AX59PRO K6-III+ 550MHz
Asus K7M Athlon 1Ghz GDF | Abit SH6 Pentium III 1GHz SL4KL...
vmr_ wrote on 2024-06-13, 19:32:From "The CPU Unicorns" series, a nice AMD k6 black top engineering sample. Alive and working, more tests later 🥳
Nice looking one, i have only ordinary K6 200Mhz (no black and no es edition).
30+ MiniGL/OpenGL Win9x files for all Rage3 cards: Re: ATi RagePro OpenGL files
Dan386DX wrote on 2024-06-13, 19:27:+3.3v = 9A (39.6W)
Em, 3.3 * 9 = 29.7
For some reason you multiplied 3.3 with 12. 😅
Dan386DX wrote on 2024-06-13, 19:27:but the label on the PSU says "MAX OUTPUT POWER 220W. (+3.3V + 5V =60W)
It's perfectly normal for PSU to have total wattage output lower than the sum of wattage outputs of each voltage.
Just got this in the mail, it looks like a matrix G200, but it has an addin card memory card and a DVI connection mini board??
Who decides what truth is, and what is their objective? Today’s falseness can reappear as tomorrow’s truth.
AGP4LIfe? wrote on 2024-06-14, 00:01:Just got this in the mail, it looks like a matrix G200, but it has an addin card memory card and a DVI connection mini board??
Im guessing you receiving this wasnt as random as your post makes out.
I got a big lot of about 30cards in the mail from ebay 🤓, I didn't know what all was in it. Many surprises!
Some people get all the cool kid toys !
It is absolutely a G200 with a DVI daughter board. I have never seen such a board but it matches the G200 I just posted a few back in this very thread.
Maybe you will have better luck than me.
Has anyone managed to get the Matrox G200 flat panel add-on to work?
Yes we had this (DVI-) topic here shortly before:
Re: Bought these (retro) hardware today
and ongoing discussion.
The DVI daughter card was an official add-on by Matrox.
Nice one! Never seen before.
RetroPC: K6-III+/400ATZ @6x83@1.7V / CT-5SIM / 2x 64M SDR / 40G HDD / RIVA TNT / V2 SLI / CT4520
ModernPC: Phenom II 910e @ 3GHz / ALiveDual-eSATA2 / 4x 2GB DDR-II / 512G SSD / 750G HDD / RX470
Mandrew wrote on 2024-06-12, 19:44:Got an EIZO Flexscan T563-T with pincushion issue. It still has decent brightness so probably worth fixing, I can't say no to cheap CRT.
Nice picture above the monitor.
Picked up this ti4200 with a passive Zalman cooler today.
Kahenraz wrote on 2024-06-14, 05:32:AGP4LIfe? wrote on 2024-06-14, 00:01:Just got this in the mail, it looks like a matrix G200, but it has an addin card memory card and a DVI connection mini board??
I don't have a DVI-D only cable but when I get one l'll try it and see what happens 👍.
Holy ... wow, just wow!
I've been slowly building up my sound card collection and grabbed an Audigy for $5 today.
I haven't done much research into Windows 98 sound, but I've seen the Audigys come up a lot, so I figured I'd grab it, especially for $5. I also picked up a Belkin OmniView Pro today. I wasn't looking for a KVM switch, but this one came up locally for $15, so I grabbed it.
I'm pretty sure this device allows you to convert a PS/2 mouse to serial, which should be convenient for me. I have a few laptops with a single PS/2 port and I'm not sure if they would support a splitter. Now I can just use the KVM switch and not worry about finding one.
Most importantly, this one is Y2K compliant, so I will be all set for the future!
Ensign Nemo wrote on 2024-06-15, 02:07:I'm pretty sure this device allows you to convert a PS/2 mouse to serial, which should be convenient for me. I have a few laptops with a single PS/2 port and I'm not sure if they would support a splitter. Now I can just use the KVM switch and not worry about finding one.
Hiya, I have this KVM model and you are correct. I have 7 PCs connected through it, 2 of which have a serial mouse connection.
I am using a USB-PS/2 mouse and AT keyboard (with adapter) to control them all.
I am also working on a little project to make it switch automatically!
Enjoy... all the cable management 😀
My system specs (Google Doc)
My game collection (CLZ Games)
acl wrote on 2024-05-27, 14:51:Nice Fury Maxx. Your's have soldered bios and jumpers in the top right corner. Mine and most i've seen have socketed bios and no jumpers. Which motherboard/chipset do you plan to use for testing ?
That's the question for a retired me in ~20 years. I have tons of stuff and next to no time for testing right now.
Ozzuneoj wrote on 2024-06-13, 02:09:demiurge wrote on 2024-06-13, 01:49:Posted the following cards to the VGAmuseum: […]
- AMD FirePro V3900
- ATI Firepro V5800
- NVIDIA GeForce FX 5200
- NVIDIA GeForce GT 430
- Matrox Millennium G200
Awesome photos. Can you describe your camera setup? In the past 5-6 years my collection has... erm... exploded... and I'd love to be able to take such clear and detailed pictures of the stuff I have.
Sorry I only shoot photos on the weekend. I made a light box out of 2x4's and wired it up as a lamp myself with an articulating spot light.
I take photos from the tripod with a Pentax X-5 that is almost retro in its own right.
The only thing I would do differently is to make sure the LED strips were cool white and not warm light.
