First post, by demiurge
I picked up this card for the VGAmuseum but I have no idea what chipset the thing uses. It is a DOME Medical Imaging (at the time of manufacture it was subsidiary of Planar) card and that is all I know about it.
I don't think I can get the heat sink off without damage--it is glued on real well. I might have already damaged it.
I am going to get my PCIX machine up and going today--I hope--so I can pull some stats. What should I run other than lspci?
https://www.ebay.com/itm/266324590838
Reply 1 of 15, by Horun
A little wayback search found this is part of the Planar Dome CX series. Cannot DL the DX2 driver w/o login (card edge has 10-DX2-01 so figure it a DX2 card)
http://web.archive.org/web/20051031194530/htt … al_drivers.html
added: maybe one of the drivers listed half down page "download now" may give some clues....
and this: http://web.archive.org/web/20060111030212/htt … /Dome/Dome.html
but this .pdf gives some limited info but does say what those lil dip switches are for...
http://web.archive.org/web/20081116202433/htt … 1A-quickref.pdf
will dig around a bit more later...have bunch chores to do
Reply 2 of 15, by demiurge
Thanks I couldn't figure it out since the card is part of the system, but it seems to be a DX2 controller card. Let's see if I can get VGA.
Reply 3 of 15, by dionb
That Xilinx FPGA looks suspiciously like it's acting as PCI-PCI bridge, I'd suspect there are actually two GPUs under the big heatsink, each with their own RAM (four chips). I'd guess they'd be something like FX5200s looking at the rest of the card.
Alternately, it's an AGP or PCIe to 64b PCI/PCI-X bridge, in which case it will be just a single GPU.
But lspci sounds like a good start.
Reply 5 of 15, by Horun
PC Hoarder Patrol wrote on 2024-06-16, 22:33:
demiurge wrote on 2024-06-16, 17:26:
May be worth a try - https://web.archive.org/web/20150317071035/ht … .14.10.0045.zip
Excellent find ! the .inf does say DX and DX2 !!!
Reply 6 of 15, by esasoft
Drivers for Windows 2000/XP:
https://web.archive.org/web/20150317071035*/h … .14.10.0045.zip
Driver for Sun Solaris:
https://web.archive.org/web/20150317030622/ht … 03A-Solaris.zip
https://web.archive.org/web/20150317070834/ht … un-solaris.html
May be worth a try
Damn, you're ahead of me! 😀)) I've just found that links too 😀)
Reply 7 of 15, by esasoft
Installing under Solaris:
https://manualzz.com/doc/60414153/planar-dome … quick-reference...
https://manualzz.com/doc/6973835/planar-dome-e3-user-manual
DX/PCI Display Controller Installation Guide
https://web.archive.org/web/20030316212227/ht … ci/DXPCI-01.pdf
DOME CXtra software:
https://web.archive.org/web/20150317025705/ht … a-5.7.2.011.zip
Reply 8 of 15, by demiurge
dionb wrote on 2024-06-16, 21:59:
My PCIX board has the dreaded code FF so I won't be able to test it but I did get the heatsink off.
It is a Xilinx Spartan XC2S600E and there are 8 × 16MB modules of DDR SDRAM for 128 MB.
I'll put it on the VGAmuseum with this information in the coming days.
Thanks all.
Reply 10 of 15, by Unknown_K
I think I have that card, will have to try it out.
Reply 11 of 15, by demiurge
rasz_pl wrote on 2024-06-17, 05:30:
Fully software defined graphic card, nice!
For a while a few companies did this:
https://vgamuseum.info/index.php/component/k2 … /904-fuji-dvi01
https://vgamuseum.info/index.php/component/k2 … nema-red-rocket
https://vgamuseum.info/index.php/component/k2 … ma-red-rocket-x
https://vgamuseum.info/index.php/component/k2 … ce-raptor-4000e
Reply 12 of 15, by rasz_pl
Did they do something special? like 24bit grayscale output (medical imaging)?
Reply 14 of 15, by rasz_pl
demiurge wrote on 2024-06-22, 23:12:
Thanks, posted to the vgamuseum
>Card for medical use in radiology
"DX board to support the DOME C3™ or C5™ digital flat-panel display"
"Dome medical imaging display systems... by NDS Surgical Imaging"
"10-bit capability"
Yay I guessed correctly 😀
https://web.archive.org/web/20030316212227/ht … ci/DXPCI-01.pdf must be for older system, its dated 2000 and only talks about 8bit palettes and 256 colors
Those ones https://www.manualslib.com/products/Planar-Dx … ci-1994559.html https://www.manualslib.com/manual/311095/Plan … ?page=15#manual mention 10bit grayscale mode for Xray inspection.
Reply 15 of 15, by ElectroSoldier
What is the display output resolution?
