Reply 2240 of 2382, by feipoa
- l33t++
gonzo wrote on 2024-06-17, 09:47:feipoa wrote on 2024-06-16, 10:30:In short, you will want to find an unused PGA-168 socket. Cut off all the pins on that socket which correspond to the incoming voltage (Vcc) from the motherboard
Am I right to use a desoldered used socket, too...? :)
Only if the used socket is in fairly good condition, nothing with solder blobs on the pins. Left-over solder on a desoldered PGA168 socket can out stretch the retaining mechanism on socket 3's.
gonzo wrote on 2024-06-19, 08:14:Thank you, pshipkov. I am a little bit disappointed with the long time for delivery from China, so I had a look at this one buck […]
pshipkov wrote on 2024-06-18, 16:06:Maximum values for Am5x86: ~5V, ~1A, ~4W.
Looks like ~1.5A buck-regulator will be fine.Thank you, pshipkov.
I am a little bit disappointed with the long time for delivery from China, so I had a look at this one buck-regulator offered from a German-trader:
https://www.conrad.de/de/p/az-delivery-lm2596 … ductDescriptionInput-voltage: 4 to 40 V
Output-Voltage: 3,3 to 24 V
Output-Amperage: 2 A constant
Very comfortable because of a display for the Output-Voltage :)
Price per piece: about 6 EuroWould this be a good choice?
By the way: how must be the negative pole (ground) of the buck-regulator connected to the PGA-168-interposer? I assume, all the Vcc-pins (23-24 pins) are all only the positive pole...
I like the display. It shows Vin and Vout. It would be even nicer if it could also show current.
Looks like Am5x86 at 3.3 V and 133 Mhz typically draws 825 mA. For over 5V and approaching 200 MHz, maybe around 1.5 A? I think the buck reg. you found should be OK.
gonzo wrote on 2024-06-19, 18:57:pshipkov wrote on 2024-06-19, 16:42:Nice device. Will be ok.
CPUs VCC pins go to vout+.
In/out negative poles of the regulator to ground.So the V(out) negative pole of the buck-regulator does not have any contact with any pin of the interposer? So it goes directly to ground somewhere on the mainboard?
This was one of the questions I had in the SXL thread. It seemed to me like connecting Vout's GND to the PGA might create a sort of ground loop, but other commenters seems to think it would be OK. Worked fine for me connecting Vout's GND to the PGA interposer.
