Reply 1860 of 3175, by robertmo3
try dosbox from here:
http://ykhwong.x-y.net/
"Older releases"
20150103
Reply 1861 of 3175, by sharangad
robertmo3 wrote on 2024-07-04, 12:44:
try dosbox from here: http://ykhwong.x-y.net/ "Older releases" 20150103 […]
"Older releases"
20150103
OK, worked with dosbox-staging!
[EDIT] It installs without the videos. The custscenes don't work.
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 1862 of 3175, by robertmo3
maybe you need to have CD mounted as D:\
Reply 1863 of 3175, by sharangad
Revised vQuake with AA link (Will update old post):
https://nirvtek.com/downloads/RReady.Alpha.20240704.002.zip
MD5: 31edf3f866027d999290372249f5966a
- vQuake should fix all AA glitches.
Reply 1865 of 3175, by robertmo3
check SPLANET.INI
Reply 1866 of 3175, by sharangad
robertmo3 wrote on 2024-07-04, 13:41:
check SPLANET.INI
That was set to
Video =video
I tried setting it to cddrive:/splanet/video didn't work. I copied the video folder into the game folder and tried again with
Video=
And
Video =video
No joy.
Also tried mounting the cd as d: and that didn't work either.
Reply 1867 of 3175, by robertmo3
i will wait for the build with fixed logging and check again then.
Reply 1868 of 3175, by sharangad
robertmo3 wrote on 2024-07-04, 14:09:
I'll try and get you a build within the next 2 days.
My priority is vquake at the moment.
Reply 1870 of 3175, by robertmo3
i don't know why you used space before "="
but i guess it makes link not work and moves directly to game's menu and game works indeed (and with sound)
(game is using space after "=" and this way link works correctly) (videos need sound to be disabled in setsound to start)
Reply 1871 of 3175, by robertmo3
what's an interesting coincidence is that in dosbox ykhwong (daum) space before "=" doesn't work in command line
Reply 1872 of 3175, by sharangad
robertmo3 wrote on 2024-07-04, 15:36:
Is that from config file. I don't remember typing cycles.
Reply 1873 of 3175, by sharangad
Using
cycles= 10000
didn't work in dosbox-Renditon for SPVerite. Vids don't playback even with sound disabled for me.
Does it work for you?
[EDIT]
I'm guessing you're talking about the software renderer.
Reply 1874 of 3175, by robertmo3
you can type in everything from config file, but things from first sections won't work immediately (more in dosbox manual)
it has nothing to do with splanet game
Reply 1875 of 3175, by robertmo3
Reply 1877 of 3175, by robertmo3
i was talking about
"Video ="
in SPLANET.INI
Reply 1879 of 3175, by sharangad
My SPlanet.ini:
[scorch]
video= video
language= 1
keymap= 0 29 37 0 0 0 0 0 0 151 0 0 0 24 0 0 37 29 31 0 0 0 0 0 0 0 0 167 0 0 0 0 22 0 0 19 18 35 33 36 34 0 0 0 0 0 0 0 187 178 179 180 181 182 183 184 185 186 0 0 0 0 0 0 0 0 1 2 131 61 4 0 133 0 0 16 6 135 139 0 137 10 140 141 14 0 0 17 15 8 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 168 169 170 171 172 173 174 175 176 177 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 37 0 30 0 32 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 156 148 155 149 188 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 25 38 26 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 29 37 0 0
gamma= 1.300000
joystick= 65535 0 1.000000 65535 0 1.000000
HighQualityVideo= 0
settings= 1 2 1 0 3 95 127 0 0 5 640
name= DEFAULT NAME
J:\SPLANET\VIDEO
language=1
