Abit AB-PB4 new info
First post, by space_eraser
Hi folks,
Undocumented 512kB WB L2 cache is possible to activate on AB-PB4 v1.3. Then BIOS identifies and posts "Enhanced Write Back Cache" instead of usual "Cache memory 256k" .
Because Ali 1487/1489 chipset supports it, two EDO 72pin double sided SIMM has been used. It seems the memory BW performance can be dramaticaly improved. I have tested enhanced Am486DX4-100 SV8B (Am486DX4-S) and Am486DX5-133W16BGC (Am5x86-P75-S). Both are using WB L1 cache. DX4 has 8kB, DX5 16kB.
Abit PB4 contains single L2 cache SRAM bank only. It consist of 4x original DIP32 Winbond W24512AK-15 L2 SRAM chips, replaced with ISSI IS61C1024-15N and 1x original DIP28 TAG SRAM Winbond W24129AK-15, replaced with UM61M256k-15.
You can see the results and enjoy 😀
Reply 1 of 19, by majestyk
Seems like you managed to completely disable L2 cache.
CPU performance and L1 cache parformance are just like every system with an Am5x86 at 4 x 40 MHZ. Nothing special at all.
Reply 2 of 19, by space_eraser
majestyk wrote on 2024-07-05, 13:01:
Yes, L1 CPU cache performace is based on nominal CPU frequency and has to be similar in all tests with the same CPU. But memory bandwidth is more complex. Look on my first post again and try think more about it. BIOS claims "Enhanced Write Back Cache", not "L2 cache disabled". Look on the cache test patterns and latency. L2 cant be disabled. Just only EDO is faster than fast. Thats why you cant see usual drop between L2 and DRAM in perf. graph. Be sure, when we return back default 256k L2 cache, you will see the drop between L2 and DRAM. And you will see also latency difference for 512k pattern, which cant be cached with 256k L2. The same result with FPM instead of EDO RAM. But latency on L2 will be still the same. It means L2 cache is still working. It seems the used cache test is limited to specific enviroment usual for 486 platform. And usual for 486 = FPM DRAM.
Reply 3 of 19, by pshipkov
Nice hint about the 512k L2 cache. Will check here.
Looks like you are running it with inflated wait states, correct ?
At least Doom fps and the Speedsys flat lines after L1 section suggest so.
Can you confirm ?
retro bits and bytes | DOS media library
Reply 4 of 19, by pshipkov
this does not work on v1.5 of the motherboard.
i used yo have version 1.3, but it had some limitations compared to 1.5, so i sold it.
Reply 5 of 19, by majestyk
But with the more advanced chipsets L2 performance hits 60 easily, so L2 could improve the range 16K-256K / 16K-512K (slightly)...or would over all memory performance suffer - and if so, why?
Is there any datasheet explaining the so called "enhanced WB cache"? They are all WB, but what makes them enhanced and why not when using 256K or 1MB?
Reply 6 of 19, by space_eraser
pshipkov wrote on 2024-07-05, 18:31:
Yes, my PB4 is v1.3.
Reply 7 of 19, by space_eraser
majestyk wrote on 2024-07-05, 18:39:
No datasheet describing "enhanced WB cache" found. It seems L2 cache is WT with default 256k chips. Generaly WB means CPU moves data to L2 and no wait for DRAM.
Reply 8 of 19, by space_eraser
pshipkov wrote on 2024-07-05, 14:48:
Can you confirm ?
Memory timing in BIOS is on the max preformace limit. Zero wait states and read/write timing 2-1-1.
Reply 9 of 19, by jakethompson1
I'm skeptical that "Enhanced Write-Back Cache" is just this BIOS' way of saying that there is no L2 cache but the CPU is an L1 WB one. The word "enhanced" is particularly associated with that.
Reply 10 of 19, by H3nrik V!
Well, since the BIOS doesn't report how much L2 cache is available, and there's no L2 listed in Speedsys, I could suspect that those who think L2 is disabled may be right ...
Reply 11 of 19, by space_eraser
H3nrik V! wrote on 2024-08-08, 07:29:
Look on the chips. Cachecheck does report. BIOS does report. In default config with 4x original DIP32 Winbond W24512AK-15 is BIOS posting "Cache memory 256k". With 4x ISSI IS61C1024-15N BIOS posts "Enhanced Write Back Cache". With original 256k L2 chache, you can see change in us/kB value between 256 and 512kB test pattern. Why ? Because 512k pattern is bigger than physical 256k L2 chache. So this pattern is not cacheable for now and thanks to this has bigger latency. But with 512kB L2 chache, 512kB Cachecheck test pattern is still cacheable. Thats why you cant see any change in latency value. It means L2 is working.
Write Trough and Write Back is general definition for data handling. It is possible to have WB L1 synchronous cache in CPU and WB L2 async cache on the board. Since the CPU L1 WB/WT scheme is defined in factory, except for some Cyrix 486, then only L2 cache can be changed depending on amount of cache vs DRAM. You cant use WB when less L2 cache installed. 256k is enough for 32MB RAM. For 64MB you need 512k or more.
Reply 12 of 19, by jakethompson1
There are several of us here with 512K and 1024K cached 486 systems, though, and our experience doesn't match what you are describing.
There should still be a "notch" in performance where it drops for memory reads bigger than the cache. It would just move from 256K to 512K or 1024K, accordingly.
Why don't you try disabling external cache in your BIOS and rerun speedsys and cachechk? I think you'll find it's the same as your screenshots above.
Did you get those ISSIs from eBay and if so did you test them with a TL-866 II? About 10% of them are bad.
Reply 13 of 19, by majestyk
jakethompson1 wrote on 2024-08-08, 23:34:
... test them with a TL-866 II? About 10% of them are bad.
And when you operate them at the nominal frequency - even with standard timings - another 50% are defective.
Only chance for valid results is using old original (for example Winbond) 15nS chips.
Reply 14 of 19, by MikeSG
What is the main memory speed before & after?
Reply 16 of 19, by space_eraser
rasz_pl wrote on 2024-08-09, 22:06:
Yeah this is no L2 cache, remove those chips and speed wont change
Sure? The same MOBO with FPM DRAM and cache shows L2 latency drop.
Reply 17 of 19, by rasz_pl
Sure that your L2 cache does nothing with EDO, might even slow it all down. Remove L2 cache chips and rerun cachechk.
Reply 18 of 19, by space_eraser
rasz_pl wrote on 2024-10-20, 21:02:
Mea culpa. You are completely right. I have spent a lot of time with testing described MOBO and results are very interestig. I have to tell the first posted idea about 512k L2 cache support feature is absolutly WRONG ! My current results are below:
1) AB-PB4 posts "Enhanced Write Back Cache" everytime, when no cache resolved, or no cache installed. It seems thats only bad BIOS message undestanding.
2) Part of my cache chips was faulty. I have tested them by my XGecu T48 programmer and found bad Tag chip and at least single IS61C1024 cache chip bad also.
3) Tag chip parameters are key factor of success. A have tried original L2 chache chips including tag chip (4x W24512AK-15 + 1x W24129AK-15) and results at 40MHz base clock are very bad. With only different Tag chip (UM61M256) are results much better. In general 15ns chips are too much for base clock more than 33MHz. Better results can be expected with 12 or 10ns chips.
So the conclusion is? Never belive cache chip sellers and never belive the BIOS posts means what you mean 😀
Reply 19 of 19, by space_eraser
Slightly improved and corrected table added. Tried also 128kB L2 cache for compare. UM61M256 chips seems to be fully stable at the max chipset timing values in BIOS. But still better performance seems to be with L2 cache off.
