Doxbox and D-Fend?
First post, by ConjurerDragon
Until now I used DOSbox 0.63 together with the frontend D-Fend v2 (2.062 build 42) and got most of my old games to run except some like Battlespire.
On the dosbox website I saw that the new DOSbox 0.72 would get Battlespire to run so I downloaded 0.72 and installed it.
Then I changed D-Fends configuration to the new path of DOSbox - and nothing worked anymore. 🙁
When I looked for an update for D-Fend I found that the author of D-Fend does no longer update that frontend.
My questions are:
1) Is Dfend v2 unable to work with DOSBOX 0.72 - or am I just unable to get it to work?
2) Was there a newer version of Dfend than mine before it was discontinued?
3) If no version of Dfend works with the new Dosbox 0.72 - which frontend will and is similar to Dfend?
My OS is Windows 98SE.
Reply 1 of 15, by Qbix
Rank DOSBox Author
DOSBox Author
try dfendreloaded. (check the dosbox general part of this forum, which is where I will move this thread as well)
Water flows down the stream
Reply 2 of 15, by Alexander
D-Fend should be able to work with DOSBox 0.72. The latest version of D-Fend can be found at http://en.wikipedia.org/wiki/D-Fend. (I haven't checked if this is your version or a newer one.)
... But using D-Fend Reloaded is a good decision, too. 😀
Reply 3 of 15, by wd
Rank DOSBox Author
DOSBox Author
Please do NOT use D-Fend with 0.70 or later. It seems to work, but fails due
to incorrect dosbox.conf settings which don't appear immediately.
Reply 4 of 15, by ConjurerDragon
Then I´ll try Dfend Reloaded. Thankyou.
Reply 5 of 15, by Neville
I know D-Fend is ancient history by now and don't want to be annoying, but could you elaborate on that? A few weeks ago, as an experiment of sorts, I tried v0.72 with the latest D-Fend beta and it *seemed* to work fine after adding some of the newest options through the "configure dynamic options" feature.
Note that this was an experiment, I normally use DOSbox through DBGL or D-Fend Reloaded for DOS gaming.
Reply 6 of 15, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
But isn't that (not even looking at other stuff like core, cycles that have changed input expectations - I don't know how or if D-Fend handles that) reason enough for telling newbies not to use it? For me the frontends reason for existence is mostly that newbies can quickly set up their games and play. If they need to figure out what to add to the config then they are probably better off just editing the conf anyway. For more advanced users like you this is not that much of an issue, you know what to expect and how to get it.
Edit: I know there are more reasons for frontends, I just shortened it since we tend to send new users with problems to frontends now and then
Reply 7 of 15, by Neville
I completely agree newbies shouldn't use D-Fend, just wanted to know more about the problems that may arise from doing so. Just curiosity, I'm not questioning D-Fend is outdated or wd's warnings.
Reply 8 of 15, by wd
Rank DOSBox Author
DOSBox Author
Some settings in the [sdl] section aren't handled by dfend but set to
bad values which caused several problems.
Reply 9 of 15, by MiniMax
Rank Moderator
Moderator
Frontends are good and bad. They are excellent when you HAVE managed to install the game, but they generally suck when it comes to INSTALL'ing the game in the first place. And that is the first hurdle any newbie needs to tackle.
_________________
Reply 10 of 15, by Neville
True. I've noticed that games won't show fullscreen properly when told to use "fullscreen" mode and "original" resolution. What you get then is the so-called "stamp mode", in which the game screen only uses the central part of the screen and you get big black borders. It can be corrected by using a 2x scaler.
Anything else?
Reply 11 of 15, by Neville
So true. Plain DOSBox and manually mounting all necessary drives is the best way to install DOS games.
Still, you can create an "installing profile", using the INSTALL.EXE as executable and mounting both the floppy / CD-ROM and harddrive units. Did the trick a few times for me, when I was a newbie and didn't know how to mount stuff manually.
Reply 12 of 15, by wd
Rank DOSBox Author
DOSBox Author
No besides that if people come up again with more ancient frontend stuff
i'll surely add explicit checks so you don't use them.
Reply 13 of 15, by Neville
Alright, then. Thanks for your time.
Reply 14 of 15, by wd
Rank DOSBox Author
DOSBox Author
Any reason for sticking to dfend?
Reply 15 of 15, by Neville
No, it was just curiousity. D.B.G.L, D-Fend Reloaded, GR-lida and have far surpassed it.
