First post, by ConjurerDragon
- Newbie
Until now I used DOSbox 0.63 together with the frontend D-Fend v2 (2.062 build 42) and got most of my old games to run except some like Battlespire.
On the dosbox website I saw that the new DOSbox 0.72 would get Battlespire to run so I downloaded 0.72 and installed it.
Then I changed D-Fends configuration to the new path of DOSbox - and nothing worked anymore. 🙁
When I looked for an update for D-Fend I found that the author of D-Fend does no longer update that frontend.
My questions are:
1) Is Dfend v2 unable to work with DOSBOX 0.72 - or am I just unable to get it to work?
2) Was there a newer version of Dfend than mine before it was discontinued?
3) If no version of Dfend works with the new Dosbox 0.72 - which frontend will and is similar to Dfend?
My OS is Windows 98SE.
