ASTRA - Advanced Sysinfo Tool for DOS
Reply 40 of 114, by Grzyb
And another sound card: Genius Sound Maker 12E
see also: 12-bit sound card
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 41 of 114, by a2kkv
Gmlb256 wrote on 2024-07-19, 01:19:
Tested the new version and noticed that the amount of memory size is 0 KB on the AWE64 in the System Summary while it is properly detected in the detailed information.
The AWE64 has a SIMMCONN module with 32 MB SIMM installed (seen as 28 MB due to EMU8K limitations).
Thank you. I will check it.
ASTRA32 - Advanced System Information Tool for Windows
Reply 42 of 114, by Grzyb
New sound card: AD1816A
Reply 43 of 114, by Many Bothans
Thanks for your work on ASTRA! Attached is the report from my Zenith Z386SX-20 system. Looks solid except for CPU detected AMD Am386SX for some reason.
  • Zenith Z386SX-20, 8MB FPM, Video 7 1024i, Unhoused
  • AOpen AP43, Am5x86-133@160, 1MB L2, 128MB FPM, Stealth III S540 32MB Savage4, SB32
  • ITX-Llama, 3Dfx V3
  • Asus CUV4X-E, P3-933, 512MB PC133, Hercules 3D Prophet II MX 32MB, SB Live!
Reply 44 of 114, by Grzyb
Two more sound cards:
CS4236
YMF719E-S
Reply 45 of 114, by Grzyb
Sound Booster Pro
by AVID Technology
seems to be an OEM variant of the original Sound Blaster Pro, with 2 x OPL2
nothing to do with "Pro AudioSpectrum", not a "Sound Blaster Pro 2.0"
I think it's pretty safe to assume that DSP 3.x + OPL2 = SB Pro 1.
Reply 46 of 114, by zuldan
Grzyb wrote on 2024-07-28, 12:07:
Sound Booster Pro by AVID Technology […]
Sound Booster Pro
by AVID Technology
I have this sound card as well plus the original manual. Would be good to get it added to Astra.
The attachment IMG_5821.JPG is no longer available
Reply 47 of 114, by Grzyb
zuldan wrote on 2024-08-02, 07:04:
All we can expect is it being recognized as Sound Blaster Pro 1, of course.
No way for software to distinguish between Creative and Avid...
Reply 48 of 114, by zuldan
Grzyb wrote on 2024-08-02, 11:09:
Maybe it can tell the difference by the existence of the CDROM connector. I think an interrupt can be queried.
Reply 49 of 114, by Grzyb
zuldan wrote on 2024-08-02, 11:18:
No, can't assume the following:
DSP 3.x + OPL2 = Avid SB Pro
DSP 3.x + OPL2 + proprietary CD-ROM controller = Creative SB Pro 1
...because the proprietary CD-ROM controller can be on a separate card.
Considering that all the important chips on the Avid-branded card are by Creative - especially the DSP - it's safe bet there's no way to tell it apart from the Creative-branded card.
Reply 50 of 114, by Grzyb
ASC TROUPER 4x4
probably the first SB16 clone
Reply 51 of 114, by Grzyb
Another computer: 486DX2/66
Reply 53 of 114, by a2kkv
ASTRA 7.11 beta has been released.
New in this beta:
- Added detailed information about VLSI VL82C480/VL82C481 chipset (memory controller mode, timings, L2 cache size and type, etc)
- Added detection of temperature of DDR5 memory modules
- Fixed detection of DDR5 memory modules
ASTRA 7.11 beta:
http://www.sysinfolab.com/files/beta/astrabet.zip
VLSI VL82C480 chipset screenshots (Intel Classic R/R Plus (Monsoon)):
The attachment chipset1.png is no longer available
The attachment chipset2.png is no longer available
The attachment comp2000.jpg is no longer available
The attachment mb2000.jpg is no longer available
Reply 54 of 114, by zuldan
a2kkv wrote on 2024-09-26, 20:03:
Thank you for the new release. I emailed support@sysinfolab.com a couple of months ago about some bugs. I also included some reports. I haven’t heard anything back. Would it be better to post the bugs here instead?
Reply 56 of 114, by Grzyb
a2kkv wrote on 2024-09-26, 19:48:
Sound Booster Pro
by AVID Technology
Strange, this card responds as Pro AudioSpectrum on 0x388 port.
Well, kind of expected, as both PAS and SB Pro 1 have 2 x OPL2...
but... is the 0x388 response different between cards with 1 x OPL2 and cards with 2 x OPL2 ?
Reply 57 of 114, by Agent of the BSoD
I tried out the latest beta and it's pretty spot on with everything. A few things that weren't right:
Sound Blaster Pro 2 being detected as Pro AudioSpectrum under Sound, but as proper Sound Blaster Pro 2.0 under Sound Blaster Compatible. Don't know how fixable that is. (this is visible in the report)
It wanted me to save a report when using a 3Dfx Voodoo Rush but it hangs the system when generating said report with flashing Please Wait dialogue. Requires a hard reset. It detected only the 2D chipset (AT25 detected as AT3D) and the Voodoo chipset was not listed.
Almost all of my S3 Virge GX2 cards report the wrong core and memory clock speeds. (these are the only cards I have that it was able to even display said info) The speeds are doubled in the output except for one, a Diamond branded one with VBIOS 1.04, which was correct. (even a Diamond card with VBIOS 1.02 was wrong)
Anyway, it marked my CPU as interesting (Intel Pentium MMX 233 MHz) so I made a report.
This is a really useful tool so I'm going to be using it from now on.
Pentium MMX 233 | 64MB | FIC PA-2013 | Matrox Mystique 220 | ESS 1688 | Music Quest MPU Clone | Windows 95B
MT-32 | SC-55mkII, 88Pro, 8820 | SB16 CT2230
3DFX Voodoo 1&2 | S3 ViRGE GX2 | PowerVR PCX1&2 | Rendition Vérité V1000 | ATI 3D Rage Pro
Reply 58 of 114, by zuldan
a2kkv wrote on 2024-09-26, 21:42:
zuldan wrote on 2024-09-26, 20:19:
Yes, please to post the bugs here.
Ok thanks.
I'm trying to get this to run on one of my machines but it sits at "Reading MSR Registers" and does nothing. If I use the /nMSR parameter then I can run the software.
I've tried the latest beta (from Vogons) and the v7.1 from the website. The machine has the following hardware.
CPU: AMD K6-2+ 550 / Memory: 64MB SDRAM
Motherboard: Gigabyte GA-5AA rev 3.2 (Super Socket 7) - ALi M1542/43/C (ALADDiN V/V+ AT) / AMD K6 Write Allocate Enabled
Video: S3 ViRGE/GX2 4MB (Diamond Stealth 3D 4000)
Video: 2x 3dfx Voodoo 2 12MB (Diamond Monster 3D II) in SLI rev A & B
Audio: Creative Sound Blaster AWE64 Gold (CT4390) (A220/I5/D1) with 28MB memory upgrade
Harddisk: CF Card (DOS) - 20GB PATA (Windows)
CD-ROM: Creative Infra 5400
I've attached a couple of report files. I also noticed on the main system info screen the 2D card info is mixed in with the Voodoo card and it's not showing the total memory for the 2nd Voodoo card. The tool also asked me to report the CPU.
I'm also wondering if it's possible for the software to show the 28MB of memory on the AWE64 Gold card?
Reply 59 of 114, by a2kkv
Agent of the BSoD wrote on 2024-09-27, 02:21:
Thank you for the report. Try to run the latest beta version.
Download link:
Fixed
