ASTRA - Advanced Sysinfo Tool for DOS
First post, by a2kkv
Hello,
I'm an author of ASTRA - Advanced Sysinfo Tool for DOS.
The attachment Summary370.png is no longer available
The attachment Summary50.png is no longer available
ASTRA works well on any PC compatible hardware (from 8086/8088 to the latest Intel Core or AMD Ryzen processors)
This program performs computer configuration analysis and diagnostics. It gives detailed information about your computer hardware and devices operational modes, including undocumented information. A unique quick HDD Health Status checker is included. It provides information on CPU, motherboard, hard disks, S.M.A.R.T., CD/DVD devices, SCSI devices, memory modules, chipset, BIOS, PCI/AGP, ISA/PnP and PnP devices, monitor, video card, sound card, network card, printer, etc. This program also creates a report file in plain text, INI, HTML, XML and CSV format, and is able to run in batch mode.
Bootable ISO and floppy images are also available.
This program FREE for non-commercial purposes.
URL: http://www.sysinfolab.com
Latest beta version: http://www.sysinfolab.com/files/beta/astrabet.zip
Windows version also available.
Please, send all your questions, suggestions, comments and bug reports.
If you want to help with the development of this program, please send the report from your system.
ASTRA32 - Advanced System Information Tool for Windows
Reply 1 of 103, by crusher
Thanks for developing this software any further for us retro lovers! 😀
Reply 2 of 103, by PC@LIVE
Thanks so much friend, it's nice that these old software are still used and updated now.
For my part, I have several PCs in my collection, unfortunately the older ones have some problems to solve, I can try running it on the PCs I have on the bench, some are not that old, but if it can be useful to you, I'll try it.
AMD 286-16 287-10 4MB HD 45MB VGA 256KB
AMD 386DX-40 Intel 387 8MB HD 81MB VGA 256KB
Cyrix 486DLC-40 IIT387-40 8MB VGA 512KB
AMD 5X86-133 16MB VGA VLB CL5428 2MB and many others
AMD K62+ 550 SOYO 5EMA+ and many others
AST Pentium Pro 200 MHz L2 256KB
Reply 3 of 103, by Rav
a2kkv wrote on 2024-07-03, 18:56:
Here the report
The attachment ASTRA.RPT.zip is no longer available
1 - If I execute Astra on my QEMM configuration, it crash. It seam to try to execute something normally in the system ROM. QEMM stealth mode relocate the BIOS somewhere else in memory to convert most of the F000->FFFF into UMB. See this screenshot for details :
The attachment crash.png is no longer available
- Other test only with himem.sys -
2 - CPU is properly identified but the frequency is incorrect, it should be around 120Mhz (40 x 3), not 62.4Mhz
3 - CPU Cache is 16KB L1, 256KB L2
4 - Sound card brand is partially identified. But model and capacity are wrong
It is a MediaVision Pro AudioSpectrum 16
It say "Sound Card Type: Sound Blaster 1.0/1.5". It is indeed compatible with that but it's much more capable when used in pro audiospectrum 16 mode
Playback Quality should be Stereo 16-bits 44100Hz
It have, indeed, an OPL3 for FM.
Seam to be all for the comments / bug report!
Reply 5 of 103, by a2kkv
Rav wrote on 2024-07-04, 06:04:
Here the report
Thank you for the report.
ASTRA only checks playback quality in Sound Blaster compatible mode.
Unfortunately I don't have Pro Audiospectrum 16 to add support for native modes.
Reply 6 of 103, by PC@LIVE
a2kkv wrote on 2024-07-04, 07:16:
PC@LIVE wrote on 2024-07-03, 21:07:
Please send any reports. This will help in development.
I will start by downloading it, from my Internet PC, a 3.6 GHz fourth generation HP i3, then I can put it in a CF with DOS 6.X, which I use on all the old PCs, when I am on the bench.
Unfortunately in this period, I am very busy, if I can this weekend, I will start a P3 600/133, and send you a file.
Reply 7 of 103, by Gmlb256
Nice! It is so far the only utility that identifies all four sound cards installed on my retro computer. 😁
One feedback though: The VIA C3 Nehemiah CPU that I have mounted on a Socket 370 slotket adapter gets identified as Antaur.
Reply 8 of 103, by Grzyb
EVERYTHING from 8088 to modern stuff in one program?
Now that's impressive!
Kiełbasa smakuje najlepiej, gdy przysmażysz ją laserem!
Reply 9 of 103, by Grzyb
The attachment 1.png is no longer available
Actually it's 512 KB, it's not possible to install 576.
The attachment 2.png is no longer available
But isn't THIS the latest?
Reply 10 of 103, by Grzyb
And here's the report...
Reply 11 of 103, by a2kkv
Gmlb256 wrote on 2024-07-05, 00:42:
Fixed
Reply 12 of 103, by a2kkv
Grzyb wrote on 2024-07-05, 01:54:
PC/XT clone, 8088, CGA video (86Box Emulator):
The attachment Summary8088.png is no longer available
AMD Ryzen5 5600:
The attachment Summary25.png is no longer available
Reply 13 of 103, by a2kkv
Grzyb wrote on 2024-07-06, 02:00:
Thank you, fixed
ASTRA 7.10 beta available.
I'll post a link to the beta version later.
Reply 14 of 103, by a2kkv
Grzyb wrote on 2024-07-06, 04:20:
The second memory module (32 MB) is not working. Check it.
  Memory Controller
Current Memory Type: SDRAM
Supported Memory Types: EDO, SDRAM
Maximum Memory Amount: 512 MB (256 MB 440EX)
Current Controller Mode: Single-channel (64-bit)
Supported Controller Mode: Single-channel (64-bit)
Channel 0 DIMM A: 64 MB PC133 SDRAM (Infineon (Siemens))
Current Memory Clock: 66.8 MHz
FSB:DRAM Ratio: 1:1
Memory Bandwidth: 534.6 MB/s
Parity: [X] disabled
ECC: [X] disabled
ECC Scrubbing: [ ]
Mirroring Mode (RAID): [ ]
ECC Chipkill: [ ]
Reply 15 of 103, by a2kkv
ASTRA 7.10 beta has been released.
New in this beta:
Added detailed information about NVIDIA TNT-GTX200 family videochips (architecture, core and memory clocks, memory type and width, temperature etc). GPU-Z for DOS 😀
Added detailed information about AMD Ryzen memory controller (supported and current memory types and clocks, controller mode, timings, etc)
Added detailed information about Intel 810/815 chipset
Added detailed information about Intel E7500, E7501, E7505, E7205 chipset
Added detailed information about Intel Atom Cedarview SOC (Atom D2xx, N2xx)
Added detailed information about Intel UL11L/US15x chipset
Added detection of core and memory clock of S3 videochips
Added MSR Walker tool (searching valid CPU MSR registers)
Improved support of Intel Meteor Lake family processors
ASTRA 7.10 beta:
NVIDIA GeForce 6200 AGP screenshots:
The attachment video1.png is no longer available
The attachment video2.png is no longer available
Reply 16 of 103, by bakemono
I have 4x interesting processors, and one interesting BIOS...
It detected a bunch of weird stuff on my 286 (SATA controller, etc.) but not the ESS1868 sound card. It detected 16 CPUs on my 486. Other than that, I will note that I have a mobile Athlon XP plugged into a board (Biostar M7VIP-pro) which does not support mobile CPUs, hence why the BIOS reports it as "Mobile Athlon 4" and boots at 1GHz. The (actual) voltage is also stuck at 1.6V AFAIK, because the board can't go lower than that. The A770-A2+ board also does not officially support Athlon II X2 280 (but it has a BIOS with patched AGESA).
GBAJAM 2024 submission on itch: https://90soft90.itch.io/wreckage
Reply 17 of 103, by a2kkv
bakemono wrote on 2024-07-06, 22:37:
Thank you. Fixed.
Is it really AXMH2000FQQ3C?
Reply 18 of 103, by bakemono
a2kkv wrote on 2024-07-07, 21:54:
Yes, that is correct.
Reply 19 of 103, by a2kkv
a2kkv wrote on 2024-07-06, 19:30:
Test stand for AGP video cards (Gigabyte 6IEM, Intel 815E, universal AGP):
The attachment 2TestStand_Small.jpg is no longer available
Set of 30 AGP video cards for debugging (Riva TNT - GeForce 6600 AGP):
The attachment 1Videocards_Small.jpg is no longer available
Celeron 733 MHz (Coppermine-128), NVIDIA GeForce 6200 AGP [NV44A] report example:
The attachment ASTRA.TXT is no longer available
