Reply 20 of 30, by DaveDDS
- Oldbie
Cursed Derp wrote on 2024-07-24, 20:56:Is there an adapter to plug a 5.25 drive into a 3.5 slot?
I'm sure there are (but a dual connector cable would be easier)
I have several systems where I swap out different types of floppy drives - I made up a cable with a 37-pin 'D' connector at
the back of the PC so that I could more easily plug "most anything" in - It only has a 5.25" drive
connector and I use various adapters to accommodate other drives.
I recently posted a photo of the adapters in your "CAN I FIT IT IN MY PC" thread!
Dave Dunfield - https://dunfield.themindfactory.com
- Dave ; https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChardware can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small FileTrans(w/o netSW)via Lan/Lpt/Serial
