Initially i had only one SXL2-66 CPU that didn't go much further than 70MHz. Regardless if air cooling or Peltier.
An important detail is that i have an ATX PSU with AT adapter on the test bench. It outputs 4.8V instead of 5V. After few more cascades down it hits the adapter with mere ~4.6-4.7V.
2 weeks ago i obtained 6 SXL2-66 CPUs. Neither of them can do stable 80MHz under the above conditions.
Bumping the Peltier to 12V didn't do anything. This is highly unusual because 12V Peltier can strap any CPU to toe the line on overclocking (assuming decent silicon die).
Discarded the direct 5V approach outlined here because it implies PSU with good 5V lines.
Went for the 12V option instead.
Inserted a PGA132 socket between the adapter and the motherboard. Removed all the 5VCC pins from it. Connected the input pin of the adapter's MIC VRM to the +12V line.
Noticed that once the VRM starts heating up the output voltage gets a bit unstable. Heatsink and fan resolved the issue.
With 5.2-5.3 V to CPU and 5V Peltier two of the processors are mostly stable at 90MHz. DOS interactive graphics tests pass, but anything more challenging than that is still unstable.
DTK PEM-0030Y which has the same performance and overclocking characteristics of 4036Y.
256Kb L2 cache
16Mb RAM
STB Nitro 2Mb (CL GD-5434)
Standard IDE + CF card.
All BIOS settings on max except:
TIMING PARAMETER SELECTION = EXTENDED (best is NORMAL)
DRAM WAIT STATE SELECTION = 2 W/S (best is 0)
BUS CLOCK SELECTOR = CLCK2/2 <--- that is 22.5MHz ISA bus
cyrix.exe -cd -e -i1 -i2
Some early results:
Superscape - 50 fps
PC Player Benchmark - 13.2 fps <--- impressive. best result to date.
Doom - 31.9 fps <--- even more impressive. not sure what to think about it yet.
Stupid good results. Much better than BL3 at 110MHz (2x55). Deep in 486 territory.
And couple of pictures from the quick Saturday morning workshop:
The attachment wide.jpg is no longer available
The attachment narrow.jpg is no longer available
The attachment ss.jpg is no longer available
The attachment pcp.jpg is no longer available
The attachment doom.jpg is no longer available
The less than 2 hours effort is inconclusive about long-term stability and peak performance.
Will see how it goes in the coming days, but the prospect of complete stability is not looking great in this first round.
Don't see how Peltier can be integrated with the SXL2-66 contraption to avoid water condensation.
Looks like the more likely path to stable system is to go through more SXL2 CPUs and find the magical one that can do 90+MHz on air cooling.
Two more notes:
100MHz is possible, but highly unstable.
SXL2-66 CPUs can survive 6.8V but don't ask how i found out.
