First post, by dragonerosso
Hi guys.
I want to know which is the Best gpu option to play modern games with my pc (i5 3570 8gb ram ddr3) with my old crt monitor ibm 8513 (highest res possible is 640x480)??? Thanks
I want gpss with only original vga input....gtx780ti will be fine??? Thanks ☺️
Reply 1 of 4, by GloriousCow
Wrong board, but just use your existing card plus a hdmi->vga dongle.
MartyPC: A cycle-accurate IBM PC/XT emulator | https://github.com/dbalsom/martypc
Reply 2 of 4, by Joseph_Joestar
If your GPU has a DVI-I port, you can use a simple, passive DVI to VGA adapter.
This is possible on my GTX 970 for example.
My retro stuff
Reply 3 of 4, by MadMac_5
I know that my GTX 980 had a DVI port that could do VGA output with a passive dongle, but I am pretty sure that the DVI connector on my Gigabyte GTX 1070 Ti could not since it was DVI-D only. I have successfully used a Startech Displayport to VGA adapter to play Control on my 19" CRT, which looked pretty great at 1024x768.
Reply 4 of 4, by BitWrangler
Yah my 1060 is digital only, I think it was spotty depending on manufacturer back to 4x0 series whether there was analog or not. If you've got two DVI and a DVI to HDMI in one of them, and only a digital port left, check under that, some cards had one with analog, one with digital, I think you get higher HDMI res on the digital one also.
