Reply 28100 of 30440, by DaveDDS
- Oldbie
Repairing a TRS-80 Model100 - an early portable computers from 1983.
I've had one of these since the 80s (one of very few computers I actually
bought new) and still use it frequently. (see it on "Daves Old Computers")
Very small - move around like a book
Instant on/off (no boot)
40x8 screen, full sized keyboard.
BASIC, decent text editor, communications and more built in.
Runs on AA batteries.
-Reportedly the last product code Bill Gates personally wrote!
I use it these days mostly to take notes while doing inventory etc.
Very easy to move around / enter data.
It gets several hours on 4 AA cells (6v), doesn't do well on NiCad or NMIH
(4.8v) - so when doing a lot of inventory it can go through a few batteries!
A while back a friend gave me one which didn't startup reliably - rough shape,
not sure why but battery clips had been removed and it's door glued shut.
I made up a 5-cell AA NMIH pack which fit nicely under the back, and would
run it for several days (and be rechargeable).. but I wasn't able to use it
much do to the startup problem (It ran fine once it came up, but you couldn't
even manually RESET it).
A bit of investigation - problem was the RESET circuit. Simple microprocessor
stuff from that era had very simple RESET - often just two components (cap
and resistor) - but this had 4 transistors, couple diodes, several caps and
many resistors, even a thermistor! - and being so early and small, no SMD and
tiny spacing of components.
(Reason for complexity is it RESETs CPU and RAM in such a way that the non-
volatile RAM couldn't be changed during power up/down)
I had to stand three of the transistors on a wire-lead stilts so that I could
take measurements while in operation in order to "figure it out".
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
