Reply 28160 of 31477, by H3nrik V!
debs3759 wrote on 2024-08-21, 15:39:
H3nrik V! wrote on 2024-08-21, 04:14:
Major Jackyl wrote on 2024-08-20, 21:55:
Oh my word. I wasn't up to this, but my brother made this abomination (for shiz and gigglez). I almost died of laughter when I actually looked at it closely. At first glance, nothing unusual, but well, a picture speaks a thousand words, 🤣
🤣 great work, but is the slot PCB actually a Slot-A or a Slot-1?
They use the same slot - slot A id the exact reverse of slot 1 physically, so they can use the same slots on motherboards.
That's kind of ironic 😀
Reply 28161 of 31477, by smtkr
TheChexWarrior wrote on 2024-08-21, 11:14:
An first retro to Gameboy game launch party for Israel indursty in a Tel Aviv mall:
https://youtu.be/nloZGAHQUtw?si=ZLSEBP4xAS9Egyxe
https://youtu.be/xBTk28t0Q-A?si=LsOARHj4t692whif
As a huge Gameboy fan (have restored/modded three DMGs this year), I salute you.
I can't get enough of these. I'm suffering through a very hard to diagnose problem with a GBA right now that will hopefully not result in turning it into ewaste 😁
Reply 28162 of 31477, by DaveDDS
DaveDDS wrote on 2024-08-11, 00:39:
Repairing a TRS-80 Model100 - an early portable computers from 1983.
I've had one of these since the 80s (one of very few computers I actually
bought new) and still use it frequently.
Now that It's working reliably - I've been having a "blast from the past" with
the TRS-80 Model100 for the past few days - gotten into some things I'd never
done with it before such as writing and installing 8085 "machine language"
applications - I've been able to poke around it's internals at a level that the
built in BASIC simply does not accomodate!
M100.COM - Updated/Improved tool to move files between Model100 and PC
ASM100.COM - easily assemble 8085 machine language code and auto-build a
- BASIC program to place in memory
M100MON.ASM - Monitor program, allowing you to read/write memory & IO ports.
- Can switch it's "console" between LCD/Keyboard and TTY(RS-232), so it's
- easy to capture such information.
In case there's anyone else who still has one , I've made these available on my site:
-> Downloads -> M100TOOL.ZIP
Dave Dunfield - https://dunfield.themindfactory.com
- Dave ; https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChardware can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small FileTrans(w/o netSW)via Lan/Lpt/Serial
Reply 28163 of 31477, by Thermalwrong
Postman5 wrote on 2024-08-21, 16:53:
They want to keep making frags:)
Dang that and the Voodoo 2 repair are so *clean*. That repair on the FBI chip is just awesome, do you use a mill to remove the edges of the package or is it freehand?
Check out the mess I made of a QFP 😀 (when all I had was the dremel which is too big for electronics work): Re: What retro activity did you get up to today?
Reply 28164 of 31477, by Postman5
Thermalwrong wrote on 2024-08-22, 03:20:
I can do it with a dremel under a microscope. It's nice that I'm not the only one.
Reply 28166 of 31477, by oldhighgerman
Why not just use a soldering iron with a short length of copper wire wrapped around the tip? So of rolled up like a snake.
Reply 28167 of 31477, by PARKE
H3nrik V! wrote on 2024-08-21, 21:21:
It makes perfect sense considering that it cut costs for motherboard manufacterers.
The attachment AthPent.jpg is no longer available
Reply 28168 of 31477, by Ozzuneoj
Postman5 wrote on 2024-08-22, 07:54:
What kind of microscope do you use? I bought one of these a couple years ago and have honestly regretted the purchase because the poor resolution, overly processed image and lack of depth perception turn the display into a big mushy mess. Also, because of the placement of the microscope in relation to the shaft, I can't actually use it on any areas that are more than a few inches into the middle of a board.
I have tried the magnifier things that you wear on your head, but I have yet to find one with enough magnifying power to actually be useful.
Reply 28170 of 31477, by Ozzuneoj
Postman5 wrote on 2024-08-22, 15:43:
Ozzuneoj wrote on 2024-08-22, 14:29:
Binocular microscope with a working distance of 150 mm
What brand and model? If I can find something comparable I would love to get one for detailed work like this.
EDIT: Is something like this actually decent? https://www.amazon.com/AmScope-SE400-Z-Profes … n/dp/B005C75IVM
I would prefer to get something better quality used for a lower price of course, but I know nothing about microscopes.
Reply 28171 of 31477, by Kahenraz
I use a standard AmScope single-boom binocular microscope, which may be similar to what Postman5 uses. That are reliable workhorse and great for repair work.
The attachment IMG_20211216_202602_resize_58.jpg is no longer available
The attachment IMG_20211216_202514_resize_21.jpg is no longer available
The attachment IMG_20211216_202549_resize_63.jpg is no longer available
The attachment IMG_20210907_144239_resize_59 (2).jpg is no longer available
The attachment IMG_20210907_143922_resize_6 (2).jpg is no longer available
I've made a number of repair threads demonstrating its capability, if you haven't seen them before.
Intel Slot 1 slocket troubleshooting and repair
NVIDIA GeForce 4 Ti 4200 triage and repair
Minor trace repair on a motherboard
Intel TC430HX Socket 7 motherboard repair
Reply 28172 of 31477, by Shponglefan
I'll second the recommendation for an Amscope microscope. I have the AmScope SM-4NTP and it's been a workhorse. I use it with the binocular eyepieces. Haven't bought a camera and screen for it, and haven't really needed to.
The base is extremely heavy which makes the whole thing rock solid when doing soldering work. The last thing you want is the microscope tipping or moving.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 28173 of 31477, by PcBytes
Finished recap of my Soltek SL-75KAV and also rigged two black holders for the 3rd SDR slot.
What's left is finding a way to remove that damaged IDE2 plastic and swap in a good blue one.
Reply 28174 of 31477, by Postman5
It’s not that all of this was absolutely necessary for repairs, but once you start doing it, it’s hard to stop.
Reply 28175 of 31477, by Postman5
I don't know how to edit the message above.
Yes, i have a microscope similar to Amscope
Reply 28176 of 31477, by BitWrangler
PcBytes wrote on 2024-08-22, 17:26:
Frequently you can just pry those up with a sturdy blade and slide them up the pins.
Reply 28177 of 31477, by BitWrangler
Found a Softkey "One Stop CD Shop" volume 1, 11 CD bundle, so I am sorted for clipart and fonts for a while. Also realised I had another Compaq 17" Monitor lurking in the back of a stack, it's a Compaq V75 not sure if it maybe "belonged" to my PMMX deskpro or my SFF PIII-600 deskpro. Looking it up, supposedly it has some decently dark blacks.
Reply 28178 of 31477, by Shponglefan
Out of curiosity, have you considered or attempted refilling the removed plastic? I wonder if something like an epoxy resin could be used to restore the missing plastic.
Or would it just potentially cause issues with thermal expansion when the chip heats up...
Reply 28179 of 31477, by Postman5
Shponglefan wrote on 2024-08-22, 20:53:
No, I'm not looking for a complete restoration. Just for it to work and be reliable.
I don't know what material to fill the missing plastic with. And it will close access to the damaged areas. The repaired connections are not as reliable as the undamaged ones.
