First post, by kingkoolkris
Maybe someone can help me out:
On my HOT433 (433AUS23 BIOS) when I enable "LBA" for my 40GB HDD it detects the primary master correctly on boot but after that nothing happens.
When I disable LBA though it boots normally, but limited to 504MB.
Is this some limitation of the 40GB HDD which is of course only detected as an 8GB HDD in the BIOS anyway?
Reply 1 of 10, by mkarcher
kingkoolkris wrote on 2024-08-30, 15:11:
Maybe someone can help me out: […]
With LBA enabled or disabled, the geometry translation is likely different. This means you need to repartition / reformat the drive if you toggle the LBA mode in "Standard CMOS setup".
Reply 2 of 10, by kingkoolkris
Ok, understood but it won't even try to boot with LBA enabled.
It's stuck right after "IDE Primary Master.....*Hard disk type"
Reply 3 of 10, by kingkoolkris
right there, no post beep.
Reply 4 of 10, by mkarcher
kingkoolkris wrote on 2024-08-30, 16:11:
Ah, I get it. Probably a BIOS bug prevents correct operation. Many hard drives of that time have a jumper to limit the capacity to 32GB. If your drive does, try to enable that mode. I don't know AMI BIOSes that well, but I am quite confident that Award BIOSes at that time did freeze with drives exceeding 32GB, if they supported drives above 8GB at all.
Reply 5 of 10, by rasz_pl
biospatcher https://www.rom.by/articles/BP/index_english.htm should be able to fix this
Reply 6 of 10, by akimmet
You have a 486 motherboard with a 1994 BIOS core. 8.4Gb is the best you can hope to get working. I don’t think biospatcher will be able to do anything with such an old BIOS.
Reply 7 of 10, by akimmet
It may be possible to patch the Award 4.51PG eSupport upgrade version 01/05/2001-UMC-881/886A-2A4X5H21C-00 using biospatcher.
https://theretroweb.com/motherboards/s/shuttl … 433-rev.-1#bios
https://theretroweb.com/motherboards/s/shuttl … 3-ver.-1-3#bios
https://theretroweb.com/motherboards/s/shuttl … 3-ver.-4.0#bios
Reply 8 of 10, by kingkoolkris
Thanks everyone, I guess I'll try to find a working HDD below 8GB!
I could verify it's working properly with a 2.1GB Quantum Fireball HDD, but this disk is near dead.
Reply 9 of 10, by kingkoolkris
Quick update: LBA enabled boot works flawlessly with a 6.4GB Maxtor drive.
Reply 10 of 10, by akimmet
Great to hear you have something working now.
