Lets build a Asus 386 mashine
First post, by Jackhead
I want to build a early Asus 386 mashine, and share the progress here.
I found a Asus ISA 386C PQ !
The attachment Screenshot 2024-09-01 124706.png is no longer available
I think the PQ has a better layout as the C, because the RAM and CPU are away from the ISA slots.
Also PQ comes with a soldered 386 DX33, what i think is perfect cpu for the time.
So this would be a 33MHz build.
About OS what was it back than? DOS 5.0?
For the RAM, i have fast 4x4 MB Sticks. Should i upgrade the cache?
This is my first 386 build i will do, so im open for suggestions!
When it comes to "time correct build" im fine with it, but PSU should be new one with -5v voltage blaster and AT/ATX adapter.
Im atm not really sure what ISA cards i should go for. I think as SPU a Soundblaster PRO?
What do you guys think?
Dos 6.22: Asus VL/I-486SV2GX4 Rev 2.0 1Mb L2 - A5x86 X5 P75 - 64MB - AHA-2842A VLB - ET4000W32P VLB - CT2230 - GUS ACE - MPU-401AT with YucatanFX
Win98SE: Asus P5K-WS - E8600 @ 4,5GHz - Strange God Voodoo 5 6000 PCI-X - 2GB DDR2 1066 - Audigy 2 ZS
Reply 1 of 37, by Shponglefan
Congrats on the board, should make for a fun build!
If you're going for a period correct build, then DOS 5.0 would be the appropriate OS for the time (i.e. 1991-1992).
For RAM, 8MB is probably the most practical (at least for gaming). Links 386 can use up to 8MB, but most games will use less. IIRC, a typical cache would have been 32kb or 64kb, so if you already have that, you should be fine. If it could support 128kb, you could look into upgrading, though it's not clear what the maximum this particular board supports. Retroweb unfortunately doesn't appear to have any documentation for this specific board.
For audio, a Sound Blaster Pro is an appropriate sound card for that era. Another option would be a Pro Audio Spectrum, although those tend to be rare and pricey.
Just a note about sound blasters of the era is they tend to be on the noisy side. If you're after an authentic retro experience, then noise will be part of it. But on the other hand, if you want something with cleaner output, there are later SB Pro compatible cards to consider instead (e.g. Yamaha Audician 32).
Were you planning on also installing the Roland LAPC-I? It would make a good pairing with whatever sound card you choose.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 2 of 37, by H3nrik V!
I would even believe that 64k of cache could've been kinda normal on a 386 ..
Reply 3 of 37, by Shponglefan
H3nrik V! wrote on 2024-09-01, 15:44:
True, looking up that specific chipset it looks like a lot of boards had 64kb cache. Unfortunately Retroweb has no manual for this specific ASUS board, so not sure what it would have supported. Though the two other ASUS boards with the same chipset do state they support 64kb cache.
Reply 4 of 37, by Jackhead
hmm pro Audio Spectrum, never had one. Would be interesting..
Yes im thinking about add the LAPC-I, and put the MPU-401AT back into my 486.
The board has 64kb cache.
Reply 5 of 37, by PD2JK
What about I/O and storage, any parts laying around?
Platters or solid state preference?
Case? PSU? 😀
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 6 of 37, by Jackhead
i have a isa I/O card. But also a xtide.
Is the scsi interface from the pro Audio spectrum good for a scsci cd drive?
Reply 7 of 37, by Intel486dx33
Here are the Specs of my 386 computer.
Intel 386 CPU with Math-coprocessor
Motherboard with 64kb cache ( 256kb of cache if you can find one )
ET4000 ISA video card ( 2mb )
ISA controller
ISA Yamaha OPL3 sound card with a Dream blaster S2GS
CDROM IDE 40-pin 4x or faster
Compact Flash for Hard drive ( Highly Recommended )
Floppy drives or Go-tech drive
Reply 8 of 37, by Jackhead
Would be a et4000 not to much for a 386? It should be for max 1991 games, and best compatible with before 91.
I also found a CT1600 really cheap (50€). So i would go with it.
Reply 9 of 37, by PD2JK
ET4000AX would be perfect, cards with this chip began shipping at the end of 1989.
Even ET4000/W32 and later are fine, they're from 1992.
CT1600 has maybe the best compatibility and real OPL3. Maybe a bit noisy in terms of SNR, but as long as you install the card in the bottom ISA slot it will pick-up the least distortion from other parts.
Reply 10 of 37, by Shponglefan
ET4000AX is a good choice. It's one of the fastest ISA video cards for DOS.
I compared an ET4000AX (Diamond SpreedStar VGA) to the WD90C31 chip (Diamond SpeedStar 24x), and the ET4000AX card was about 5% faster in benchmarks.
Reply 11 of 37, by Intel486dx33
I think the Dreamblaster X2GS with real instruments sound is way better than the Yamaha OPL3 MIDI synthesis sound.
- Waveblaster compatible connector for use on soundcards (such as Soundblaster 16, Audician 32, ESS AudioDrive, Aureal Vortex 2,...)
DreamBlaster X2GS SE features a preloaded officially licensed, read only 16mbyte GS bank.
Additionally it supports an updatable user bank (up to 48mbyte). This user bank is preloaded with Buran 1.1 bank.
X2GS BANK INFORMATION :
Full GM/GS implementation
128 GM instruments
180 variation instruments
More than 200 drum sounds in 15 drum sets + 1 SFX set
All samples are in 16bit quality
Official Dream/Roland License
Link:
https://www.serdashop.com/X2GS-SE
Reply 12 of 37, by Jackhead
Got the Board today, what a beauty! But its a DX-40 not 33!
First look on the board, its in great condition nothing broken or bend. But i also have now 386 questions.
About the external battery, the case can hold up to 2 coins, one cr2032 is installed. What are the second for?
The DX40 has a 80Mhz osc, what the second place for ? For the FPU? So do i need another 80Mhz one for the FPU?
What FPU should i use? I know its not really used for games, but i like to add one..
I also read about misterBios, should i change the bios?
edit: i see 66M on the OSCB, so i gues its for the dx33 ..
The attachment IMG_7276.JPG is no longer available
The attachment IMG_7277.JPG is no longer available
Reply 13 of 37, by PD2JK
Jackhead wrote on 2024-09-03, 11:43:
Open up the case, but I think you can place two batteries in parallel for longevity sake. One is enough though.
Hint; look at JP3. 😉
Since there aren't AMD 387 processors, I would look for a Cyrix Fasmath. Or an Intel 387, but then you need a 66MHz cyristal as well. And remove the semi-permanent jumper and put it in Async mode.
For fun yes. For normal operation no.
Reply 14 of 37, by Jackhead
Ok, so if i found a 387-40 i can just add it and dont need more modification?
Is it also so simple that i can push in a 66MHz OSC and my cpu runs at 33 mhz?
Reply 15 of 37, by PD2JK
Jackhead wrote on 2024-09-03, 13:43:
2x correct 😀
Reply 16 of 37, by BitWrangler
There has been some new ULSI 3c87 FPU going for reasonable money on fleabay. If you benchmark those on science and actual mathematics oriented benchmarks, they only perform in the top half, but if you benchmark them in games, they do well, even being best in some instances (It's that whole optimizing common instructions at the expense of less commonly used instructions thing). However, most of the '92 up games that can use an FPU still play very very slowly on a 386, so it's only for bragging rights, realistically, even DX2/66 are too slow to have a smooth experience on those games.
Reply 17 of 37, by Jackhead
thanks for the infos guys!
so for the ISA slots my plan is now:
voltage blaster for -5v
Adaptec 1542CF for scsi cd and floppys
XTIDE for 4gb CF
CT1600
ET4000AX
LAPC-I
Reply 18 of 37, by Shponglefan
Noticed that the top ISA slot is slightly offset on this board.
Does it function as a normal ISA slot or is it something proprietary? I suppose if it's a normal ISA slot it would be a good place to install the Voltage Blaster.
Reply 19 of 37, by Jackhead
i think its not isa, its for a ram expansion board.
Putting in the voltage blaster is maybe not a good idea 😀
I also found a really rare cd drive i love to use with the build. A Sony CDU920S. Its a master burner caddy drive single speed SCSI. Fun fact it was also used to make master discs for the Playstation development. I have the external one the CDU921S. I didn't even know this existed as internal drive as well.. It can also burn gold discs for mastering. A really cool drive you dont see often..
The attachment IMG_7278.jpeg is no longer available
