Marco Polo
First post, by koniciwa
Hi all,
I'm having trouble running Marco Polo with DosBox 0.72 under Vista.
After executing the game, it plays the intro and subsequently hangs.
Any help is greatly appreciated
Thanks.
Reply 1 of 4, by MiniMax
Rank Moderator
Moderator
Read my 60 Seconds Guide to DOSBox.
If that doesn't help, come back with details on how you mounted your C and D drives, how you did the install, how you configured sound, music etc.
_________________
Reply 2 of 4, by koniciwa
Hi MiniMax,
Thanks for taking the time to reply. The following are my settings in dosbox.conf:
mount c c:\oldies
MOUNT D F:\ -t cdrom -ioctl
c:
According to HOTU (http://www.LINK.DELETED), the game is a full cd-rip but lacks a setup or install file. Anyway, I made 2 copies, on my harddisk and a cd-rom. Both experienced the same issue of freezing after intro. As for the game settings, the music seems to play at default settings and seeing there isn't a setup file, I couldn't really do anything about that. I have disabled sound in dosbox.conf and it still can't get pass the intro.
Thanks,
Edit by MiniMax: Link to illegal download deleted
Reply 3 of 4, by MiniMax
Rank Moderator
Moderator
Since you are using an illegal copy I suggest you take your questions to where you obtained it. Experience tells me, that this is not caused by a problem with DOSBox, which seems to be confirmed by Marians positive entry in the compatibility database, and the fact that I don't see other posts about the game here.
_________________
Reply 4 of 4, by koniciwa
Okay, thanks anyway MiniMax
