First post, by Benweighman
I downloaded Night Trap and it came with a version of DOSbox and some instructions on how to use it,
[/quote]. Set-up DOSBox
After launching DOSBox, there are only
two commands you will ever have to rem-
ember to launch Night Trap.
FIRST, TYPE:
mount c C:\
(Replace the 'c' and 'C:/' with your hard
drive letter. 99% of users will have "C"
as default.)
THEN, TYPE:
mount d d:\ -t cdrom
(Replace the 'd' and 'D:\' with your CDROM
drive letter the Night Trap disc is in or
mounted to. This is probably "D" or "E" for
real drives, and "F" for virtual drives.
I enter this and nothing happends, it just says 'Drive C is mounted as local directory' then 'Mscdx: mounted subdirectory: limmited support.
Drive F is mounted as cd rom F:/'What am i doing wrong?
