Audigy 2 ZS SB0350 crackling noise in games
First post, by Old_mATX
Hi guys,
Got this card recently and discovered it’s “known” flaw.
The question is whether it’s the driver issue or capacitors as others said on this forum.
Whenever I see those posts that say that capacitors are the culprit, they all mention that it starts crackling at the boot. Mine only does it in games after about 30 minutes or so.
My CD image came from this community.
I THINK, I might have polluted drivers issue too. I still see some remnants of the built-in audio in control panel, even though I uninstalled it and disabled on-board audio.
What I have done so far as a mitigation but no success:
Moved it to the last PCI away from GPU
Disabled all sliders except waive
Disabled EAX
Reduced hardware acceleration
Didn’t try yet:
OS reinstall
Driver setup in the following order: chipset, Audigy 2 ZS, GPU
PCI latency in BIOS
Caps replace
Any thoughts?
Thanks!
Reply 1 of 26, by Pickle
might be worth posting some pics of the card.
check for loose pins?
Reply 2 of 26, by akimmet
What motherboard and chipset dose your system have?
Some motherboards and chipsets are known to have trouble with PCI sound cards. Dropouts and crackling audio were common problems with these motherboards.
Reply 4 of 26, by Old_mATX
akimmet wrote on 2024-09-10, 02:35:
Yes, forgot to mention my mobo: ASRock P4I65G, chipset (nb): Intel 865G , sb: Intel ICH5.
Reply 5 of 26, by Old_mATX
Shponglefan wrote on 2024-09-10, 02:36:
Do you have a different motherboard / system you could test it with?
If you can test it with another system, that could narrow down the issue to whether it's a system specific issue.
Only modern system with Windows 11, doubt this will work under it.
Reply 6 of 26, by Old_mATX
Pickle wrote on 2024-09-10, 02:00:
Yes, I will post later.
Reply 7 of 26, by Old_mATX
Interesting update I have. I've installed Q2 and enabled its music via the patch and ogg files. So, after more than 1 hour play, no crackling sounds!
I assume it's a driver issue rather than hardware.
Can anyone suggest correct way of installing Audigy 2 drivers? Does it follow after the chipset and then GPU, or chipset, GPU, sound card?
And lastly, what about Phil's lab drivers for 9x? It seems to be newer than from CD image from Vogons? Is it worth to update to 4.12.16.2100?
https://www.philscomputerlab.com/sound-blaster-audigy.html
Reply 8 of 26, by Pickle
I use this cd image for mine on win98: https://www.vogonsdrivers.com/getfile.php?fil … 510&menustate=0
chipset usually first, i dont think it will matter if video or audio comes next.
was the crackle there at the start and then it went away over time? if you never used this card before maybe the caps are reforming.
Reply 9 of 26, by Old_mATX
I bought it used, so not sure if was stashed previously, but it looked very clean.
The crackling started in games only, after playing for more than 30 minutes only go away after reboot.
I used same link to install, I've installed all programs from this CD as well. I switched to VXD version after setup.
Its manual says that we need to install driver prior to plugging the card to PCI! Curious if this is the way for Win 98?
My plan is to reinstall Windows 98 over the weekend and preform specific drivers setup.
Reply 10 of 26, by Pickle
Old_mATX wrote on 2024-09-12, 20:51:
i think this is mainly to get the driver to install from the first windows detection, its not going to hurt to do it that way, but i think the driver update path would work too if the device is first showing up as unknown
Reply 11 of 26, by Intel486dx33
Yes it works under Win-10 and Win-11 but some functions will not work like EAX.
You have to use the Audigy RX driver for Win-10 you can download from creative website.
It sound okay.
But if you Really want Great sound get the Creative GC7 Dac.
This thing sounds Amazing.
Works with PC and Mac. Plug and Play. drivers install automatically.
Wow….This thing will take your Computer Audio to Another Level.
I have both installed on same computer running Win-10 and Win-11 dual boot.
The GC7 Dac sounds so much better.
I don’t even listen to the Audigy 2zs anymore.
Reply 12 of 26, by Shponglefan
Old_mATX wrote on 2024-09-12, 18:40:
I typically install sound card drivers last. I'll usually install GPU first just to get the proper screen resolution going, followed by chipset drivers, DirectX, then sound card.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 13 of 26, by Intel486dx33
For Win-10 or Win-11 Download the Audigy RX driver from Creative website.
Extract the package file using Win-rar
Open the folder labeled “Win-10 driver” and install the driver.
You hear cracking and popping sound because you have the Wrong driver installed.
Quick uninstall that driver and software before you damage your speakers and sound card.
Reply 14 of 26, by Old_mATX
Intel486dx33 wrote on 2024-09-13, 03:31:
For Win-10 or Win-11 Download the Audigy RX driver from Creative website. Extract the package file using Win-rar Open the folder […]
Ok, but what's correct driver then? Where to obtain it? To my surprise, crackling disappeared for the last few days but Creative setup left my system unstable, I have more freezes than ever, hence I will rebuild it.
Reply 15 of 26, by Intel486dx33
What operating system are you running ?
Reply 18 of 26, by Old_mATX
It's very strange, but crackling noise completely gone by itself in all games. I didn't do anything dramatic. I will rebuild the OS with specific drivers only to bring stability back. I have on-board audio parts still in. My auto-run function is popping with some errors after Creative setup.
Reply 19 of 26, by Old_mATX
I just reinstalled an OS and only installed known good drivers as well as followed SB Au. 2 ZS guide found on this forum, so far system seems rock solid! I have to put few more games I had issues with thought.
