First post, by Old_mATX
- Newbie
Hi guys,
Got this card recently and discovered it’s “known” flaw.
The question is whether it’s the driver issue or capacitors as others said on this forum.
Whenever I see those posts that say that capacitors are the culprit, they all mention that it starts crackling at the boot. Mine only does it in games after about 30 minutes or so.
My CD image came from this community.
I THINK, I might have polluted drivers issue too. I still see some remnants of the built-in audio in control panel, even though I uninstalled it and disabled on-board audio.
What I have done so far as a mitigation but no success:
Moved it to the last PCI away from GPU
Disabled all sliders except waive
Disabled EAX
Reduced hardware acceleration
Didn’t try yet:
OS reinstall
Driver setup in the following order: chipset, Audigy 2 ZS, GPU
PCI latency in BIOS
Caps replace
Any thoughts?
Thanks!
Asrock p4i65g, Socket 478 P4 2.4, RAM 512 MB, Intel 2.5, 80 GB SSD, BFG GeForce FX 5700 Ultra, Sound Blaster Audigy 2 ZS, Roland monitors MA-8, CHASISS InWin, Windows 98 SE
IntelliMouse laser and Logitech keyboard.
