This is a yes. I have many things to share with you all!! I'll start with the MAIN REASON I bought a 3D printer: Lian-Li Face Clips.
The attachment LIAN_LI_MALE.png is no longer available
The attachment LIAN_LI_FEMALE.png is no longer available
I came across a couple of sweet cases, but they were missing the power supply bracket (two hole version, will share, too) and just as important: all the face clips were broken. They were 5 bucks , so hell yeah, I'm grabbing them. I realized how unusable they were when I got them home and was saddened, as I had many boards needing a good home. It was then I ran down to the store, bought a Creality Ender-3 V3SE and some printer fuel. Soon as I got home I downloaded the software to see what file type it needed (should've done that first). STEP is the ONLY file I could export that would be usable by Creality Print (5.1). STLs come into Print not-to-scale.
I only had one half of the female side of the clip, but I was able to recreate it quite accurately. The Male side was easy, though getting them out of the face breaks the originals. I recently needed the Males for a case I got last week, so that was more recent.
The attachment 20241119_175740.jpg is no longer available
They fit VERY WELL, in EVERY PC60 variant I've put them in AND work in the X500, so I'm going to assume, if it looks like this, this is the one.
The attachment LIAN_LI_CLIPS.zip is no longer available
Daily Units:
ASUS P55TVP4, P-MMX233, Matrox2064W, CT2770
ABIT IS7, P43.2(SL7E6), PNY6600GTS, Audigy(0090)
ASUS M2N-SLI, A64X2-5600+, EVGA 8600GTx2, Audigy2(0240)
ASUS ST-990FX, FX-8350, MSI GTX760x2, SB X-Fi(0460)
MSI Z690, i9-12900K, MSI RTX3090, SB AE-7
