Retro 3D print topic
First post, by red_avatar
I often see posters mention using 3D prints to replace stuff like brackets, front panels, buttons, keys and so on but wouldn't it be a good idea to have a (stickied?) topic where we collect 3D print designs for retro needs? It would make it a lot easier for those looking for replacements parts to find everything in a single location.
Retro game fanatic.
IBM PS1 386SX25 - 4MB
IBM Aptiva 486SX33 - 8MB - 2GB CF - SB16
IBM PC350 P233MMX - 64MB - 32GB SSD - AWE64 - Voodoo2
PIII600 - 320MB - 480GB SSD - SB Live! - GF4 Ti 4200
i5-2500k - 3GB - SB Audigy 2 - HD 4870
Reply 1 of 113, by Srandista
Just yesterday I (or rather my wife, at work) printed mount for OLED display on my Gotek drive.
You can find it on Thingiverse: Gotek drive emulator OLED mod
Reply 2 of 113, by derSammler
Having just bought my second 3D printer (DLP this time), I'd say why not? But I don't see how this would fit here.
Reply 3 of 113, by wiretap
Full Height 5.25" to single, dual 3.5" floppy & HDD adapters
https://www.thingiverse.com/thing:2217061
3.5" floppy drive case for Amstrad CPC 6128
https://www.thingiverse.com/thing:1516470
Raspberry Pi Retro Computer
https://www.thingiverse.com/thing:3478048
5.25" to 3.5" adapter
https://www.thingiverse.com/thing:2234935
Compact Flash (CF) To 3.5" IDE adapter mount
https://www.thingiverse.com/thing:1026187
3.5" Drive Bay Gotek Floppy Emulator Bracket
https://www.thingiverse.com/thing:3387674
3.5" Housing for IDE2SD Card PCB
https://www.thingiverse.com/thing:3232293
My Github
Circuit Board Repair Manuals
Reply 4 of 113, by wiretap
Ghost town... let's bring this back to life.
I'm using a Longer LK5 Pro for large PLA prints, and my super old Powerspec 3D Pro for ABS prints.
The prints below are with Jessie Amiga 500 color PLA.
Printed a floppy housing + Gotek 3.5" bay tray on Chrismas day.
Enclosure: https://www.thingiverse.com/thing:4754335
Gotek tray: https://www.thingiverse.com/thing:4760666
The attachment PXL_20211225_111502958.jpg is no longer available
The attachment PXL_20211225_172213759.jpg is no longer available
The attachment PXL_20211225_205402850.jpg is no longer available
And printing this right now.. Baby-AT case I designed in Sketchup yesterday. It is just the front panel. The 5.25" + 3.5" bay holder that mounts to it is almost done too -- I just need to get the screw hole placement put in the 3D model. Size is roughly 275mm tall by 175mm wide. The back side has holes for 10mm 6-way cube mounts that will be super glued in place, then lexan/acrylic will be what the rest of the case is made from. It should hopefully go together pretty easy.
The attachment sketchup-386-486-case.JPG is no longer available
The attachment PXL_20220103_005104691.jpg is no longer available
My Github
Reply 5 of 113, by schlomoe99
This topic included some useful files to 3D print IO shields for ATX cases to accept AT motherboards:
ATX I/O shield models for 3D printing
Here's a 3D print to fit Baby AT motherboards into certain mATX cases:
Re: Bought these (retro) hardware today
Here's a topic about a 3d print file for a replacement MT-32 knob:
MT-32 Replacement Knob
Edit: added second topic and link
2nd Edit: added third link to topic
Reply 6 of 113, by wiretap
It printed nice.. however a few of my dimensions are a millimeter or two off. Need to revise the design slightly, then it will all fit.
The attachment PXL_20220103_184953020.jpg is no longer available
My Github
Reply 7 of 113, by debs3759
wiretap wrote on 2022-01-03, 01:21:
I thought it died before it took off 😀 Probably very useful for those with a 3D printer though (I doubt I could afford one even if I had the space 😀 )
Reply 8 of 113, by red_avatar
debs3759 wrote on 2022-01-03, 21:36:
During Black Friday you could a solid 3D printer for €168 (Artillery Genius) so it's really not THAT expensive. I print stuff all the time - only thing I've yet to find is a filament that has just the right colour of beige to fit a standard PC case. I got close though but it's a little too reddish.
Retro game fanatic.
Reply 9 of 113, by wiretap
Microcenter had the Creality Ender 3 Pro for $99 just before Chrismas. I picked up my Longer LK5 Pro (300x300x400mm prints) for $188 shipped on Aliexpress's 11/11 sale. They're definitely cheap these days. I paid around $700 for my PowerSpec 3D Pro back in 2014 or so.. 🤣.
My Github
Reply 10 of 113, by Aaron707
wiretap wrote on 2022-01-03, 19:57:
Looks great! What filament did you use?
Reply 12 of 113, by douglar
This is a "SATA ssd hdd female hard drive to ide 3.5" 40 pin male converter card "
The attachment s-l1600 (1).jpg is no longer available
Plus this:
The attachment s-l1600.jpg is no longer available
Plus this:
The attachment s-l1600 (2).jpg is no longer available
Wrapped in this:
https://www.tinkercad.com/things/jjtWAFC32NP-msata-to-35
Gets this---
The attachment Photo Aug 24 2024, 2 12 25 PM.jpg is no longer available
The attachment Photo Aug 24 2024, 2 16 08 PM.jpg is no longer available
Doesn't do WDMA though =(
Reply 14 of 113, by Major Jackyl
This is a yes. I have many things to share with you all!! I'll start with the MAIN REASON I bought a 3D printer: Lian-Li Face Clips.
The attachment LIAN_LI_MALE.png is no longer available
The attachment LIAN_LI_FEMALE.png is no longer available
I came across a couple of sweet cases, but they were missing the power supply bracket (two hole version, will share, too) and just as important: all the face clips were broken. They were 5 bucks , so hell yeah, I'm grabbing them. I realized how unusable they were when I got them home and was saddened, as I had many boards needing a good home. It was then I ran down to the store, bought a Creality Ender-3 V3SE and some printer fuel. Soon as I got home I downloaded the software to see what file type it needed (should've done that first). STEP is the ONLY file I could export that would be usable by Creality Print (5.1). STLs come into Print not-to-scale.
I only had one half of the female side of the clip, but I was able to recreate it quite accurately. The Male side was easy, though getting them out of the face breaks the originals. I recently needed the Males for a case I got last week, so that was more recent.
The attachment 20241119_175740.jpg is no longer available
They fit VERY WELL, in EVERY PC60 variant I've put them in AND work in the X500, so I'm going to assume, if it looks like this, this is the one.
The attachment LIAN_LI_CLIPS.zip is no longer available
Daily Units:
ASUS P55TVP4, P-MMX233, Matrox2064W, CT2770
ABIT IS7, P43.2(SL7E6), PNY6600GTS, Audigy(0090)
ASUS M2N-SLI, A64X2-5600+, EVGA 8600GTx2, Audigy2(0240)
ASUS ST-990FX, FX-8350, MSI GTX760x2, SB X-Fi(0460)
MSI Z690, i9-12900K, MSI RTX3090, SB AE-7
Reply 15 of 113, by Major Jackyl
I was working on sorting my memory yesterday and decided this is pretty much finalized: A Memory Rack (of sorts).
The attachment 20241121_172114.jpg is no longer available
I was starting to have memory on every surface AND barfing out the drawer, so I decided to hit the work computer and cook up something cool.
The attachment MEMRACK.png is no longer available
It holds quite a bit of memory. I would like to note, though, I didn't measure a "tall" memory, so none of those.
The attachment 20241121_172157.jpg is no longer available
The attachment 20241121_172230.jpg is no longer available
Luckily, personally, I only have three of them and they are SD. The heatsink memory doesn't fit either. Again, only three, so I'm good, but I might make a "performance" DDR2 tray and DDR3 to hold memory with heatsinks.
The attachment MEMRACK.zip is no longer available
Daily Units:
Reply 16 of 113, by Ozzuneoj
Very cool stuff guys! I will be bookmarking this thread.
I know this thread wasn't created with "request a 3D printed part" in mind, but if anyone has access to one of the incredibly rare CD-ROM (caddy) drive bezels for the IBM PS/2 Model 90, the community (well... I 🤣 ) really need a printable model to for it. I wouldn't have the faintest idea of how to make a model from scratch that looked right and fit correctly, so perhaps if someone had physical access to one it would make reproduction a lot easier.
https://ardent-tool.com/90/Common.html#5_25_Bezels
It is the top one in this picture:
https://ardent-tool.com/90/Bay_B_Bezels_CDROM.jpg
Also, the system in this LGR video has one: https://www.youtube.com/watch?v=Bhvfa3zRaGs
Reply 17 of 113, by CharlieFoxtrot
Ozzuneoj wrote on 2024-11-22, 01:10:
Very cool stuff guys! I will be bookmarking this thread. […]
As you hinted, it is next to impossible to make such design without good measurements of EVERYTHING and original parts are rare. But you don’t need the original part, but the ability to solve the requirements to making working substitute. However, it is mandatory to have the possibility to print drafts, testing those prototypes and adjusting tolenrances so that it actually fits like it is supposed to, that is test everything on a real machine.
Have you tested these if either can be adapted to your needs?:
https://www.thingiverse.com/thing:6694504
https://www.thingiverse.com/thing:4572066
And if that is close, it may a good starting point to work on making the design needed. That isn’t that complex of an object to design, so you won’t need CAD superskills with it, but you need to start learning. There are countless of learning videos for most popular CAD software in YT.
Reply 18 of 113, by Major Jackyl
I recently found these Industrial Lian-Li cases and learned something: There are at least TWO different male clips... These cases need a piece that is a bit longer. I'll have that here, just incase this case is more common than I think.
The attachment Screenshot 2024-11-25 192535.png is no longer available
The attachment 20241125_201649.jpg is no longer available
The attachment 20241125_214202.jpg is no longer available
The attachment Long_Clip.zip is no longer available
Daily Units:
Reply 19 of 113, by H3nrik V!
Made a 5.25" bezel to house 2 USB connectors (Bulgin PX0843/a which can be separated from the big, round housing and plug in here)
Anyone in luck finding some beige PLA filament? Or is painting still the way to go.
I'll share both STL and Fusion files, if anybody wants (it could be ½-1 mm narrower, I guess - or it may be my printer not being trimmed properly.
https://www.bulgin.com/us/products/front-pane … -connector.html
