Reply 54480 of 58197, by Linoleum
I still can't believe this... I got my hands on a very clean, error free, Compaq Prolinea 4/50 for $100 Canadian dollars.
In my roster, this PC is going to cover the 1988-1992 era... I'll probably try to install MS-DOS 5.1 with DirectAccess 5.1 menu system. I'll be adding my Audician32 Plus with a WavetablePi and increase RAM to 16Mb. I might try to add a 5.25 floppy drive if prices could stop skyrocketing.
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge, SB32, PicoGus
486DX4 100, CLGD5424, SB32
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA, Forte16
PS2 30/286, SBP
Reply 54481 of 58197, by PcBytes
A batch of goodies to come my way:
- 2x ABIT AB9 Pro (i965?)
- ABIT BH6 (440BX)
- various RAM
- MSI H61M-P20 (G3)
- Soltek SL-65LIV-T (PLE133T)
- Intel D815EEA (i815)
- Apple OEM Rage 128 Pro, P/N 109-63000-00 - anyone know a PC BIOS that works with this card?
- Mecotek MK-694V3 (aka Luckystar 6VA694, the non-plus variant w/ DIPswitches)
- Gigabyte GA-6VA (VIA 693/596)
- DFI P2BLX Rev A (440LX)
- Azza PT-5VMD (MVP3) - might be a candidate for a cache transplant from my dead K6BV3 🤣, I don't mind using a 1MB chip on it if it'll support it.
- Soltek SL-65KIV2 (694X) - interesting lil' board w/ISA 😀
Reply 54483 of 58197, by H3nrik V!
luckybob wrote on 2024-09-25, 04:12:
MY MACHINE IS BIGGER THAN YOURS!!! I got myself a IBM PC Server 704 (Quad Pentium Pro) […]
Gallery:
https://imgur.com/gallery/behold-ibm-pc-serve … hinator-s6jAvUv
Found this on Facebook marketplace. $150 and a 2-hour round trip. LITERALLY the only reason I have FB is marketplace and the IBM PS/2 owners group. (It's a private IBM circle-jerk) Speaking of jerks, I had to clean myself up after I pulled out the memory board. 16x ECC 128mb 72-pin SIMMS for a total of 2048mb. (in the gallery)
I'll make a separate thread about this absolute unit. I'm going to service the power supplies before I just ram the angry pixies into them. The PSUs show signs of heavy use (dusty) so its likely the RIFAs are going to pop like firecrackers if I just plug her in.
Holy fudge, that's cool. I won't ask why the roll of toiletpaper is only on one picture ... 🤣
Reply 54484 of 58197, by H3nrik V!
I'll probably never have as cool stuff as Bob, but this is kinda cool, when I get them modded for dual Coppermine action and popped in my Asus P2B-DS with 1024 MiB of memory and a pair of 1.1 GHz 100Mhz CPUs which is already in the drawer ... 😎
Gonna test run them with a couple of 933s at 100 MHz first though, to not fry the 1100s
Also need to figure out some cooling, as there's not much room between the slots ...
Reply 54485 of 58197, by Trashbytes
H3nrik V! wrote on 2024-09-26, 09:06:
Gallery:
Need something to clean up after the raging banana.
Reply 54486 of 58197, by Wes1262
Gallery:
Looks like my heat pump!
Reply 54487 of 58197, by eesz34
Linoleum wrote on 2024-09-25, 18:19:
I love these little Prolineas for some reason even though they stand for everything I hated back in the day. I have a 3/25zs so no extra drive bays at all.
Reply 54488 of 58197, by Repo Man11
Wes1262 wrote on 2024-09-26, 10:50:
Gallery:
Has this happened to you? You spot a beige rectangular something somewhere and immediately think "Is that an abandoned computer?" only to get a good look and realize it's actually an abandoned microwave...
And speaking of that, it has occurred to me that this hobby of playing with/working on old computer hardware probably seems as strange to many outsiders as collecting old toasters or microwave ovens would.
Reply 54489 of 58197, by BitWrangler
Oldschool SFF, LPX, proprietary and cramped form factors are not so "scary" any more. There is no worries about if/how you can upgrade them in the future, because that future has already happened as far as their potential goes. You are not "stuck" with it as a large investment sole PC that you need to get a few years out of. Many tips and wrinkles, hacks and mods have been figured out in the intervening years. Modern storage is massive, you don't need to worry about adding another 3.5 HDD year on year as your storage needs expand, so don't really care about internal drive bays beyond one or two. Worried you'll need the full 19" slot length to expand the graphics at all? It didn't really happen, there was always shorter cards, unless you wanted top of the range monster, but you know what, the half the size midrange from following gen does just as well.
Anyway, they won't suit the people who wanna get 5 soundcards in one box or things like that, but for building a set configuration, they are fine, even desirable because they often take up half the space of an AT or ATX standard lump. It's also more fun with the artificial constraints to try to "build them out to the limit" to see what the most you could do with it was, you have to get more inventive, creative... devious.
I would not recommend them for beginner retro machines, by choice, better to learn the ropes on a "standard" XT, AT or ATX format and cased machine or two. However, should you have your old one, or get given one, or find one at pocket change pricing, then while they might lead to extra bumps in the learning curve, they can still be worth it. Well known brands usually have enough information online these days to prevent extreme frustration in getting them to do anything.
Reply 54490 of 58197, by luckybob
that's because its paper towels. And I needed to use them to clean up the mess I made when I pulled out that fully loaded memory board.
Reply 54491 of 58197, by PD2JK
How much memory do you want?
Yes.
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 54492 of 58197, by acl
AGP4LIfe? wrote on 2024-09-25, 14:26:
Not sure on the production date, ill have to look at the back of the card, when I get home. I do believe its early 2000.
It does have standard clocks, 120Mhz Gpu, 150Mhz Ram. Posted a 3D Mark 2001 SE 3,501 Score.
Very nice card. I only have 32MB versions. Still looking for a 64MB 😀
But.... i have a 16MB GeForce 256 SDR which is weird and not very common. With lower clock than standard.
Trashbytes wrote on 2024-09-25, 15:17:
I had not seen a 64Mb DDR model before mine so its nice to see another in working order !
The 3d glasses are kinda cool too but more of a novelty rather than useful.
I tested the ELSA Revelator glasses that were bundled with a GeForce 2.
Results vary depending on games.
Generally HUDs break the immersion because the appear in the front and you have to focus your eyes on the text to read it, then focus again to the game.
Games without HUDs are fine
Reply 54493 of 58197, by eesz34
BitWrangler wrote on 2024-09-26, 14:18:
I assume that was in response to my post? Anyway, if so, I'm not complaining about lack of expandability. Back when the Prolinea 3/25 and similar were new I wouldn't have bought one because while they are cute, they are proprietary and have little expansion. Today, it doesn't matter to me if they are expandable/proprietary or not. For me it's a novelty and they already are limited simply due to their age. But all this is what makes them interesting.
Reply 54494 of 58197, by AGP4LIfe?
acl wrote on 2024-09-26, 17:21:
Very nice card. I only have 32MB versions. Still looking for a 64MB :) But.... i have a 16MB GeForce 256 SDR which is weird and […]
Does it also have a 64 or 32 Bit Memory bus?? instead of 128Bit?
Who decides what truth is, and what is their objective? Today’s falseness can reappear as tomorrow’s truth.
Reply 54495 of 58197, by acl
AGP4LIfe? wrote on 2024-09-26, 17:49:
Normal 128bit according to GPUZ (https://retro.user-unfriendly.net/Parts ... apture.PNG)
110/143 MHz but it overclocks to normal clocks without issues (even a bit beyond iirc). I posted a YT video of this card for GPUJune2 some years ago.
It was defective when i got it. With a greenish image. But i was able to fix that in the oven 😁
Some pictures of it : https://retro.user-unfriendly.net/Parts ... /pictures/
Reply 54496 of 58197, by BitWrangler
Nanah nanah nanah nanah, nanah nanah nanah nanah Trackman!
Yup it's BW showing off his baller stuff again.. trackballer
This one is in nice shape looks barely used, in contrast to my other which was a bit well worn and crufty. Unfortunately the mouseport adapter, disk, and paperwork are missing. However, having the mouseport mode at leasts let you wire it up if you need it, also think I got a weirdy thing that does MP thru the 9 pin. I think I am up to 3 mouseport devices for 3 ports now.
Reply 54497 of 58197, by marxveix
2 x MSI ATi Radeon HD 2600XT 512MB 128-bit GDDR3 PCI Express x16 HDCP Ready
CrossFire Supported Silent Heat Pipe Video Cards for XP gaming with Catalyst 7.11
https://www.msi.com/Graphics-Card/RX2600XTT2D … 3/Specification
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / DVD : ATi RagePro drivers and software
30+MiniGL / OpenGL Win 9x dll files for all ATi Rage3 cards : Re: ATi RagePro OpenGL files
Reply 54498 of 58197, by Wes1262
Repo Man11 wrote on 2024-09-26, 14:03:
Gallery:
LMAO
Reply 54499 of 58197, by AGP4LIfe?
Been chasing this one for about a year and a half.. Finally caught one for a bargain price(Under $50.)Not amazingly rare but kinda hard to find in good working condition, with the platinum designation.
Presenting the ATI X850XT PE AGP
The attachment PXL_20240927_145623151.jpg is no longer available
The attachment PXL_20240927_145638117.jpg is no longer available
