Reply 54580 of 58196, by devius
What about 3.1?
Reply 54581 of 58196, by PD2JK
Yes, that would be pünktlich. 😏
Good collection!
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 54582 of 58196, by schmatzler
devius wrote on 2024-10-04, 18:14:
What about 3.1?
Goddammit, I totally forgot about that one. Well...seems like I still need to complete my collection 😁
(I barely used it during my youth, unlike all of the other operating systems, that's why it must've slipped my mind).
If I pursue that, I do want to get 3.11, though.
Reply 54583 of 58196, by devius
Sorry 😅
Reply 54584 of 58196, by zuldan
ChrisK wrote on 2024-10-04, 10:41:
A word of warning: Have an eye on real Vcore if you happen to change it in the BIOS. I remember it behaving a bit "odd" i.e. not […]
A word of warning:
I remember it behaving a bit "odd" i.e. not what you would think it to be. Depended on the type of cpu used iirc, coppermine/tually, but was definitely not correct.
We don't want any 1400 end up grilled do we...
Edit: note to myself: check own board for those patches on the cpu socket. Maybe these make for some difference in this vcore thing...
Thanks for the heads up. I don’t have any plans for overclocking, especially for hardware I can’t easily replace.
Reply 54585 of 58196, by Wes1262
What a week.
Creative Labs Geforce 2 MX 400 128 bit "reference" with DVI/VGA and S-video daughter board
Geforce 2 Ti, 8500LE, FX5700, X850XT, 7800gtx, 3870 x 2, 3870 x 2 again, GTX 295 dual pcb, GTX 295 single pcb
Reply 54586 of 58196, by BitWrangler
Wow, did you perform sexual favors for the GPU fairy or something 🤣
Reply 54587 of 58196, by Wes1262
It's very possible none of them works though 😁 I got them for very cheap and they are in terrible shape
EDIT forgot also: 3850 AGP, 775 dual vsta in dubious state, 775i65g rev 2
Drivers downloaded... time to test something..... 😁
Reply 54588 of 58196, by PC@LIVE
Well in the last few days, I had the time to dedicate myself to a PCCHIPS M550, coincidentally also on YouTube in the "Necroware and Tony359" channels, there are videos on the S.7 topic, it's true we talk about some cards, but they I found it interesting, coming back to me, the M550 had a behavior that made me think of a problem with the BIOS, among various difficulties I managed to recover it, I'm currently doing some benching at a reduced frequency (133 MHz instead of 166), but the final goal is to go more or less at 400 MHz, with a 2.2V AMD K6-2 CPU, even if the minimum voltage of this MB is 2.5V, so a little more than what would be necessary, I don't know if there is a simple way to reduce the voltage, without the use of an intermediate socket like upgradeware or similar.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
Reply 54589 of 58196, by myne
Might be possible.
It has jumpers for voltage.
https://theretroweb.com/motherboards/s/pcchips-m550#docs pg 5.
2 possible approaches.
1) correlate the jumpers to the VID pins on the CPUs. They might be a 1:1 mapping and thus undocumented voltages should appear.
2) suck it and see. Find a test point that reliably shows vcore on a multimeter. Pull the CPU and ram. Turn on, confirm voltage still 2.5. Try all the undocumented combinations.
But tbh, 10%higher voltage isn't really a concern
I built:
Reply 54590 of 58196, by RandomStranger
I haven't bought much recently. On today's vintage market I found this and took a 2€ gamble.
The attachment IMG_20241006_103923.jpg is no longer available
The seller had an OEM socket 370 universal AGP motherboard. In that case it was more than likely dead. I couldn't pry off the CPU cooler. If I could verify it having a high-end Tualatin-S, I'd also took a gamble on that. I have decent luck with expansion cards on this market. It's rare to find something interesting, but when I do, they are dirt cheap and generally work.
Reply 54591 of 58196, by PcBytes
TNT2 Ultra?
Reply 54593 of 58196, by PcBytes
Today's scores:
- Premier LC-C400ATX PSU - long time since I last dealt with these 🤣
- ASUS P5GD1-VM w/ P4 and badcaps (Lelon)
- Asrock K8NF6G-VSTA
- Matsonic MS8308EP(266) + Duron 1100
- PCChips M825G + Athlon T-Bird 850
- 40GB Excelstor Europa, aka Hitachi Deskstar 180GXP (nice)
- 40GB WD Caviar
- 80GB Maxtor Diamondmax Plus9
- 500GB Hitachi Deskstar
- 128MB SDRAM by TMC
Reply 54594 of 58196, by AGP4LIfe?
PcBytes wrote on 2024-10-06, 09:18:
TNT2 Ultra?
Looks like a TNT Standard with the 7ns ram I believe even a "pro" should have 6ns, Love the asus brand build though, looks great!
Who decides what truth is, and what is their objective? Today’s falseness can reappear as tomorrow’s truth.
Reply 54595 of 58196, by RandomStranger
AGP4LIfe? wrote on 2024-10-06, 14:16:
TNT2 Ultra?
I don't know if it's actually an ultra. Different sources say different things. It certainly has a lot of stuff missing from the PCB, but it seems to match this aside of the RAM:
from the VGA museum, but mine is missing all the ultra markings from the sticker on the VGA connector and the GPU. Otherwise different sources suggest different things from the standard TNT2 through Pro all the way up to Ultra. ASUS had a very confusing naming scheme back then. I got it believing it's a standard TNT2 so it would be a pleasant surprise if it turns out to be an ultra, but probably not. I'll se when/if it turns on. Probably the day after tomorrow or next weekend.
Still, my other TNT2 colcks at 125/125 so having one on 125/150 is still an upgrade.
Edit: This is also very similar, still a standard TNT2:
http://hw-museum.cz/vga/158/asus-riva-tnt2-vivo
Reply 54596 of 58196, by BitWrangler
RandomStranger wrote on 2024-10-06, 14:22:
Yah, I hate it, every time I have to figure out an ASUS TnT or GF2 card, or see one for sale, lots of M64s getting passed off as GTS/Ultra/GF2 as well, and you really gotta zoom in on PCB.
Reply 54597 of 58196, by AGP4LIfe?
I don't know if it's actually an ultra. Different sources say different things. It certainly has a lot of stuff missing from the […]
TNT2 Ultra?
The bios sticker says ,V38T1 should be a standard clock TNT2. Also if there is a back sticker that says "C1AV85" you know that's the case. Overclock though!! 😁
Reply 54598 of 58196, by RandomStranger
Then that settles it. It's a standard TNT2. The only question now if it works at all.
Reply 54599 of 58196, by Turbo ->
Bought this Asrock P4i45E motherboard. Smaller capacitors need replacing. I love early P4 motherboards. This would be an interesting Windows 98 build.
